/ Forum / PREGEO e DOCFA / G.P.S. / SCARTO SQM ELEVATO SULLA STAZIONE 100
Autore SCARTO SQM ELEVATO SULLA STAZIONE 100
overland
24 Marzo 2010
BN
 0 -  0 - Inviato: 03 Aprile 2013 alle ore 18:05
Allego il mio libretto pregeo
0|26032013|12|G626|0150|9|xxxxxxx|GEOMETRA|BENEVENTO|
9|880|10|20|25800|10.00-G,APAG 1.13|MC|xxxxxxxxxxx|
1|100|4647469.47,1187614.98,4189875.91|0.000|Stazione virtuale|
6|L2|22032013-09:37|23032013-17:10|RTK|PDOP=1|
2|130|-6120.001,17834.694,2753.541|0.00054902,0.00012031,0.00018865,0.00010464,0.00005821,0.00018511|PDOP=2|2.108|Spigolo pozzetto [VRS]|
2|101|-6229.446,17970.121,2843.626|0.00051192,0.00011476,0.00026356,0.00014364,0.00006936,0.00027974|PDOP=2|2.108|Spigolo Fabbricato|
2|102|-6229.649,17967.134,2844.486|0.00048413,0.00012317,0.00022587,0.00014524,0.00007609,0.00023349|PDOP=2|2.108|Spigolo Fabbricato|
2|103|-6230.460,17969.148,2844.909|0.00051192,0.00011476,0.00026356,0.00014364,0.00006936,0.00027974|PDOP=2|2.108|Spigolo Fabbricato|
2|104|-6231.850,17965.194,2847.657|0.00104564,-0.000001614,0.00044095,0.00014837,-0.000001762,0.00033271|PDOP=3|2.108|Spigolo Fabbricato|
2|105|-6233.673,17965.857,2849.555|0.00112793,0.00003415,0.00053152,0.00016222,0.00003206,0.00039411|PDOP=3|2.108|Spigolo Fabbricato|
2|106|-6232.799,17966.832,2848.275|0.00104564,-0.000001614,0.00044095,0.00014837,-0.000001762,0.00033271|PDOP=3|2.108|Spigolo Fabbricato|
2|107|-6235.281,17967.489,2850.923|0.00137252,-0.00012201,0.00082734,0.00017584,-0.00011339,0.00072873|PDOP=3|2.108|Spigolo Fabbricato|
2|108|-6235.241,17971.882,2849.933|0.00165071,-0.00022035,0.00082402,0.00033326,-0.00008817,0.00058988|PDOP=3|2.108|Spigolo Fabbricato|
2|109|-6233.025,17974.253,2846.679|0.00090368,0.00009121,0.00037028,0.00016100,0.00006401,0.00027979|PDOP=2|2.108|Spigolo Fabbricato|
2|110|-6233.015,17974.251,2846.700|0.00090604,0.00009295,0.00037105,0.00016149,0.00006456,0.00027986|PDOP=2|2.108|Spigolo Fabbricato|
2|111|-6231.067,17973.866,2844.596|0.00071549,0.00006453,0.00024464,0.00012987,0.00004664,0.00019599|PDOP=2|2.108|Spigolo Fabbricato|
2|112|-6232.111,17972.603,2846.141|0.00090604,0.00009295,0.00037105,0.00016149,0.00006456,0.00027986|PDOP=2|2.108|Spigolo Fabbricato|
2|113|-6235.320,17971.997,2850.051|0.00086698,-0.00001855,0.00030403,0.00020462,0.00003313,0.00023643|PDOP=2|2.108|Spigolo Fabbricato|
2|114|-6235.386,17968.990,2850.672|0.00128165,-0.00015821,0.00063917,0.00024920,-0.00008622,0.00051694|PDOP=3|2.108|Spigolo Fabbricato|
2|115|-6234.470,17970.286,2849.449|0.00128165,-0.00015821,0.00063917,0.00024920,-0.00008622,0.00051694|PDOP=3|2.108|Spigolo Fabbricato|
2|116|-6224.759,17976.284,2836.948|0.00077521,0.00002113,0.00033300,0.00012899,-0.000005334,0.00031707|PDOP=2|2.108|Spigolo Fabbricato|
2|200|-6225.427,17979.304,2836.704|0.00141683,-0.00005897,0.00080832,0.00017728,-0.00007346,0.00068151|PDOP=3|2.108|Spigolo Fabbricato|
2|118|-6223.032,17977.245,2834.716|0.00141683,-0.00005897,0.00080832,0.00017728,-0.00007346,0.00068151|PDOP=3|2.108|Spigolo Fabbricato|
2|300|-6218.673,17964.850,2832.386|0.00061199,0.00016263,0.00033649,0.00018929,0.00007057,0.00040528|PDOP=2|2.108|Spigolo Fabbricato|
2|120|-6216.800,17964.532,2830.634|0.00061331,0.00016617,0.00033446,0.00019161,0.00007228,0.00040035|PDOP=2|2.108|Spigolo Fabbricato|
2|121|-6217.749,17966.406,2831.143|0.00061331,0.00016617,0.00033446,0.00019161,0.00007228,0.00040035|PDOP=2|2.108|Spigolo Fabbricato|
2|123|-6203.995,17976.959,2813.005|0.00136215,0.00021453,0.00056466,0.00019806,0.00008959,0.00041940|PDOP=3|2.108|Spigolo Fabbricato|
2|PF09/0150/G626|-6205.206,17978.643,2813.932|0.00136215,0.00021453,0.00056466,0.00019806,0.00008959,0.00041940|PDOP=3|2.108|Spigolo Fabbricato|
2|126|-6209.332,17991.769,2815.296|0.00124748,-0.000001491,0.00068458,0.00016449,-0.00003596,0.00056914|PDOP=3|2.108|Spigolo Fabbricato|
2|127|-6212.185,17993.156,2818.037|0.00154289,0.00011317,0.00087682,0.00020187,0.00003890,0.00069311|PDOP=3|2.108|Spigolo Fabbricato|
2|PF14/0090/G626|-5959.410,17455.524,2622.333|0.00072039,0.00039807,0.00052140,0.00035163,0.00038205,0.00065815|PDOP=3|2.108|Termine|
2|PF14/0160/G626|-6110.396,18171.903,2721.376|0.00033028,0.00006646,0.00017707,0.00008270,0.00005910,0.00028512|PDOP=2|2.108|Spigolo gabbionata|
2|PF07/0150/G626|-6294.833,17943.792,2941.350|0.00112115,0.00004879,0.00044587,0.00007506,0.00004217,0.00032950|PDOP=3|2.108|croce scalfita|
1|200|1.57|p.f.|
2|121|271.7495|15.990|spigolo fabbricato|
2|201|160.8136|2.190|spigolo fabbricato|
2|202|180.4777|1.607|spigolo fabbricato|
1|300|1.60|p.f.|
2|121|160.8136|2.190|spigolo fabbricato|
2|301|148.0027|29.583|spigolo fabbricato|
6|punti vertice|
7|1|118|PV|
7|1|121|PV|
7|1|301|PV|
6|contorno fabbricato|
7|5|103|106|115|112|103|RC|
8|PF07/0150/G626|-32665.266000|25216.626000|52|CENTRO CROCE SCALFITA A PUNTILLO SU ROCCIA AFFIORANTE|
8|PF07/0150/G626|893.000000|04|CROCE SCALFITA A PUNTILLO SU SOMMITA' SPUNTONE ROCCIA AFFIORANTE|
8|PF14/0160/G626|-32988.613000|25394.516000|52|SPIGOLO GABBIONATA. LATO NORD|
8|PF14/0160/G626|851.127000|04|SOMMITA' SPIGOLO GABBIONATA.|
8|PF14/0090/G626|-33039.385000|24659.393000|52|TL TRA LE PART.147-148-151 MURO CINTA(SOST. IL PF 11)|
8|PF14/0090/G626|768.903000|04|SOMMITA' TERMINE|
8|PF09/0150/G626|-32828.901000|25228.764000|52|SPIGOLO SUD FABBRICATO(SOST. IL PF 05)|
8|PF09/0150/G626|806.897000|04|BASE SPIGOLO FABBRICATO. QUOTA PAVIMENTAZIONE ESTERNA.|
QUANDO ELABORO IL LIBRETTO IN PREGEO MI ESCE TUTTO VERDE, GLI SQM DEI VERTICI SONO BUONI MENTRE QUELLI DELLA STAZIONE 100 SONO ELEVATI, QUALCUNO SA DIRMI IL MOTIVO? GRAZIE ANTICIPATAMENTE!
 0 -  0 - Inviato: 03 Aprile 2013 alle ore 19:30
Se spari a raffica i tuoi libretti in giro per il forum poi finisce che ci gira la testa.
Ti ho risposto da un'altra parte.
 0 -  0 - Inviato: 03 Aprile 2013 alle ore 19:59
per l'esattezza qui:
www.geolive.org/forum/pregeo-e-docfa/gps...
probabilmente lì c'era da leggere troppa roba!
e sapete......., va molto di moda aprire nuove discussioni, strafregandosene apertamente dei solleciti a fare le ricerche ed a mettersi in coda....!
sarà che sono su con gli anni e a qualcuno dà fastidio i miei solleciti!
ma vedo e constato che i giovani con la fretta, poi, tanto lontano non vano!
overland
24 Marzo 2010
BN
 0 -  0 - Inviato: 04 Aprile 2013 alle ore 10:05
Chiedo scusa Geoalfa e samsung, non è un problema leggere troppa roba, è la prima volta che scrivo sul forum.. ho visto dall'altra parte e ho risposto.. grazie dei consigli
