Buongiorno,
ho eseguito un TF inerente 7 p.lle originarie (stessa ditta, qualitą e classe) con fusione delle derivate a costituire 3 lotti. Le singole particelle orginarie non sono state rilevate per intero ma 2 dei tre lotti in costituzione sono vettorializzati con poligono chiuso.
Allego modello censuario.
6|51FTP|033|
6|O|2219 |000| | |000003380|SN| | |003|03|
6|S|2219 |000| | |000000000| | | |000| |
6|C| |000|a |AAA |000000147|SN|A |AAA |000| |
6|C| |000|b |AAB |000000315|SN|B |AAB |000| |
6|C| |000|c |AAC |000000027|SN|C |AAC |000| |
6|C| |000|d |AAD |000002891|SN| | |000| |
6|O|4781 |000| | |000000060|SN| | |003|03|
6|S|4781 |000| | |000000000| | | |000| |
6|C| |000|a |AAE |000000059|SN|C |AAC |000| |
6|C| |000|b |AAF |000000001|SN|D |AAF |000| |
6|O|6066 |000| | |000000410|SN| | |003|03|
6|S|6066 |000| | |000000000| | | |000| |
6|C| |000|a |AAG |000000409|SN|A |AAA |000| |
6|C| |000|b |AAH |000000001|SN|C |AAC |000| |
6|O|6068 |000| | |000002240|SN| | |003|03|
6|S|6068 |000| | |000000000| | | |000| |
6|C| |000|a |AAI |000002151|SN| | |000| |
6|C| |000|b |AAL |000000089|SN|A |AAA |000| |
6|O|6070 |000| | |000001730|SN| | |003|03|
6|S|6070 |000| | |000000000| | | |000| |
6|C| |000|a |AAM |000000888|SN| | |000| |
6|C| |000|b |AAN |000000822|SN|A |AAA |000| |
6|C| |000|c |AAO |000000009|SN|B |AAB |000| |
6|C| |000|d |AAP |000000011|SN|C |AAC |000| |
6|O|7714 |000| | |000001531|SN| | |003|03|
6|S|7714 |000| | |000000000| | | |000| |
6|C| |000|a |AAQ |000000079|SN|C |AAC |000| |
6|C| |000|b |AAR |000000020|SN|C |AAC |000| |
6|C| |000|c |AAS |000001432|SN|D |AAF |000| |
6|O|7715 |000| | |000000139|SR| | |003|03|
6|S|7715 |000| | |000000000| | | |000| |
6|C| |000|a |AAT |000000132|SN|C |AAC |000| |
6|C| |000|b |AAU |000000007|SN|D |AAF |000| |
6|M31FU|004|
6|O|AAA |000| | |000001467|SN| | |003|3 |
6|V|AAA |000| | |000001399|SR| | |003|3 |
6|O|AAB |000| | |000000324|SN| | |003|3 |
6|V|AAB |000| | |000000330|SR| | |003|3 |
Ho introdotto il modello ausiliario per inserire la SR dei lotti poligonati per intero.
Devo definire le SR direttamente nel modello Frazionamento e riproporzionare le superifici delle altre derivate?
La p.lla 7715 ha in banca dati SR ma le derivate le ho indicate come SN in quanto non rilevate. E' corretto?
In fase di approvazione la procedura mi da' i seguenti errori.
Particella AAA: sbilancio tra la superficie dell' originale (1467) e quella delle
derivate (1399). [ps]
Particella AAB: sbilancio tra la superficie dell' originale (1467) e quella delle
Particella AAB: sbilancio tra la superficie dell' originale (324) e quella delle
derivate (330). [ps]
Grazie mille a chi potrą darmi un aiuto
