/ Forum / PREGEO e DOCFA / PREGEO / sospensione tipo
Autore sospensione tipo
stellamay
23 Novembre 2005
 0 -  0 - Inviato: 09 Novembre 2007 alle ore 16:37
Volevo sapere se qualcuno, gentilmente, poteva spiegarmi questo tipo di errore.
tipo protocollato il 05/11/2007:11:15:19 con numero VV0134014 id_pratica sister =
0000000014456105 Motivi di rifiuto ERRATA SUPERFICIE REALE PART. DERIVATA AAB VEDI
STAMPA PREGEO; IL TRATTEGGIO CHE DOVREBBE ESSERE UNA VERANDA DEL FABBRICATO AAC NON
PUO INSISTERE SALLA PARTICELLA AAA, QUINDI VA SCORPORATA LA SUPERFICIE
Riporto una parte del lavoro:
0|
9|0|10|20|-50577|9.00-G,Stda 3.12|MC|GPS TOPCON IPER PRO|
1|100|4799103.71,1361596.54,3961154.81|1.571|
6|L2|24102007-13:37|24102007-15:09|RTK|PDOP=1|
2|101|7.109,34.460,-18.092|0.00020,0.00002,0.00009,0.00004,0.00001,0.00010|PDOP=2|2.300|Spigolo fabbricato|
2|102|12.953,31.482,-24.108|0.00014,0.00002,0.00005,0.00005,0.00002,0.00007|PDOP=2|2.300|Spigolo fabbricato|
2|103|12.128,18.745,-18.603|0.00027,0.00002,0.00006,0.00004,0.00002,0.00013|PDOP=2|2.402|Spigolo Fabbricato|
2|104|1.295,33.883,-9.417|0.00026,0.00007,0.00006,0.00015,0.00003,0.00007|PDOP=2|2.402|Spigolo Fabbricato|
2|105|10.185,44.452,-23.270|0.00014,0.00002,0.00006,0.00005,0.00001,0.00010|PDOP=2|2.402|Spigolo Fabbricato|
2|106|0.169,24.891,-6.170|0.00017,-0.00001,0.00018,0.00013,-0.00006,0.00045|PDOP=3|2.402|Spigolo Fabbricato|
2|107|10.768,52.500,-25.884|0.00046,0.00003,0.00011,0.00007,0.00002,0.00011|PDOP=2|2.402|Spigolo Fabbricato|
2|108|15.357,54.618,-31.730|0.00039,0.00003,0.00007,0.00007,0.00002,0.00008|PDOP=2|2.402|Spigolo Fabbricato|
2|109|12.146,51.905,-27.522|0.00013,0.00004,0.00006,0.00005,0.00002,0.00011|PDOP=2|2.300|Spigolo fabbricato|
2|110|11.869,55.651,-29.234|0.00013,0.00002,0.00008,0.00005,0.00001,0.00013|PDOP=2|2.300|Spigolo fabbricato|
2|111|11.958,59.781,-30.751|0.00014,0.00002,0.00006,0.00005,0.00001,0.00010|PDOP=2|2.300|Spigolo fabbricato|
2|112|14.827,58.599,-33.800|0.00016,0.00002,0.00005,0.00004,0.00001,0.00006|PDOP=2|2.300|Spigolo fabbricato|
2|113|14.657,50.669,-30.887|0.00026,0.00004,0.00009,0.00005,0.00002,0.00009|PDOP=2|2.300|Spigolo fabbricato|
2|114|15.052,50.506,-31.308|0.00039,0.00003,0.00007,0.00007,0.00002,0.00008|PDOP=2|2.300|Spigolo fabbricato|
2|115|17.790,49.378,-34.217|0.00026,0.00003,0.00010,0.00005,0.00001,0.00014|PDOP=2|2.300|Spigolo fabbricato|
2|116|17.412,41.439,-31.052|0.00026,0.00003,0.00010,0.00005,0.00001,0.00014|PDOP=2|2.300|Spigolo fabbricato|
2|117|6.836,30.605,-16.448|0.00010,0.00002,0.00004,0.00004,0.00002,0.00009|PDOP=2|2.300|Spigolo fabbricato|
2|118|14.807,42.522,-28.307|0.00027,0.00010,0.00010,0.00017,0.00001,0.00019|PDOP=3|2.402|Spigolo Fabbricato|
2|122|-4.372,28.281,-0.881|0.00023,0.00002,0.00012,0.00005,0.00002,0.00013|PDOP=2|2.402|Recinzione|
2|124|17.118,23.728,-25.330|0.00020,0.00002,0.00009,0.00004,0.00001,0.00010|PDOP=2|2.402|Recinzione|
2|126|14.074,-0.188,-15.093|0.00010,0.00002,0.00004,0.00004,0.00002,0.00009|PDOP=2|2.402|Recinzione|
2|PF03/0080/H271|-41.362,-42.641,61.278|0.00011,0.00002,0.00005,0.00004,0.00002,0.00015|PDOP=2|2.402|Spigolo Fabbricato|
2|PF05/0080/H271|-28.058,335.741,-55.033|0.00044,0.00002,0.00004,0.00004,0.00002,0.00007|PDOP=2|2.402|Spigolo Fabbricato|
2|PF09/0080/H271|134.590,-135.394,-116.059|0.00017,0.00003,0.00007,0.00010,0.00018,0.00061|PDOP=3|0.202|Spigolo Fabbricato|
7|7|106|104|117|101|102|103|106|RC|
7|9|105|118|114|113|108|110|109|107|105|RC|
7|4|118|116|115|114|RT|
7|4|108|112|111|110|RT|
6|6| ***** Fine Relazione ***** |
8|PF03/0080/H271|-55473.591|-50719.122|50|PP - SOMMITA' VASCA - SPIG. NORD|
8|PF05/0080/H271|-55639.175|-50360.291|50|P.P. SOMMITA' VASCA SPIG. EST VASCA [ TRIFILO' - LARIA ]|
6|51FTP|005| |
6|O|254 |000| | |000002180|SN| | |049|02| |
6|S|254 |000| | |000000000| | | |000| | |
6|C| |000|a |AAA |000001891|SN| | |049|02| |
6|C| |000|b |AAB |000000212|SN| | |049|02| |
6|C| |000|c |AAC |000000077|SN| | |049|02| |
6|3SPC |004| |
6|O|AAB |000| | |000000212|SN| | |049|02| |
6|V|AAB |000| | |000000212|SN| | |282| | |
6|O|AAC |000| | |000000077|SN| | |049|02| |
6|V|AAC |000| | |000000077|SN| | |282| | |
6|M31FU|006| |
6|O|AAA |000| | |000001891|SN| | |049|02| |
6|V|AAA |000| | |000001891|SN|FM| |000| | |
6|O|AAB |000| | |000000212|SN| | |282| | |
6|V|AAB |000| | |000000212|SN|FM| |000| | |
6|O|AAC |000| | |000000077|SN| | |282| | |
6|V|AAC |000| | |000000077|SN|FM| |000| | |
6|ESTRATTO DI MAPPA|
8|1%|-55028.646|-50399.953|
8|2%|-55039.586|-50387.903|
8|3%|-55038.896|-50387.243|
8|4%|-55036.916|-50389.353|
8|5%|-55034.486|-50387.403|
8|6%|-55035.216|-50386.413|
8|7%|-55033.736|-50384.903|
8|8%|-55027.776|-50391.333|
8|9%|-55023.786|-50387.953|
8|10%|-55021.456|-50385.743|
8|11%|-55017.526|-50390.903|
8|12%|-55021.796|-50394.913|
8|13%|-55023.376|-50396.423|
8|14%|-55024.146|-50395.873|
8|15%|-55024.066|-50388.863|
8|16%|-55021.926|-50391.693|
8|17%|-55023.236|-50393.133|
8|18%|-55575.516|-50690.693|
8|19%|-55602.326|-50647.723|
8|20%|-55620.036|-50659.513|
8|21%|-55619.956|-50650.653|
8|22%|-55619.216|-50642.153|
8|23%|-55615.856|-50635.693|
8|24%|-55611.966|-50630.653|
8|25%|-55604.026|-50625.963|
8|26%|-55583.876|-50619.553|
8|27%|-55554.816|-50663.883|
8|28%|-55538.826|-50749.623|
8|29%|-55551.116|-50729.673|
8|30%|-55571.956|-50696.383|
8|31%|-55547.296|-50672.463|
8|32%|-55536.496|-50688.653|
8|33%|-55532.896|-50694.873|
8|34%|-55514.566|-50737.993|
8|35%|-55528.316|-50745.453|
8|36%|-55530.986|-50746.793|
8|37%|-55764.493|-50119.317|
8|38%|-55744.599|-50115.099|
8|39%|-55741.982|-50116.455|
8|40%|-55736.443|-50131.612|
8|41%|-55758.448|-50131.348|
8|42%|-55757.692|-50135.939|
8|43%|-55758.676|-50135.933|
8|44%|-55766.306|-50135.883|
8|45%|-55766.466|-50121.853|
8|46%|-55765.864|-50121.079|
7|11|18%|19%|20%|21%|22%|23%|24%|25%|26%|27%|NC|254|254|2211|
7|0|18%|NC|
6|ESTRATTO DI MAPPA AGGIORNATO|
8|106*|-55561.391|-50668.464|
8|104*|-55566.189|-50660.150|
8|117*|-55574.421|-50664.869|
8|101*|-55576.548|-50661.248|
8|102*|-55584.222|-50665.757|
8|103*|-55577.180|-50677.741|
8|105*|-55584.199|-50652.523|
8|118*|-55590.561|-50655.682|
8|114*|-55594.462|-50648.093|
8|113*|-55593.925|-50647.825|
8|108*|-55595.699|-50644.228|
8|110*|-55591.844|-50642.258|
8|109*|-55590.011|-50645.925|
8|107*|-55588.011|-50644.964|
8|116*|-55594.074|-50657.457|
8|115*|-55598.175|-50649.948|
8|112*|-55597.702|-50640.266|
8|111*|-55593.811|-50638.322|
7|11|18%|19%|20%|21%|22%|23%|24%|25%|26%|27%|NC|AAA|254|1917|
7|0|18%|NC|
7|9|105*|118*|114*|113*|108*|110*|109*|107*|105*|RC|AAA-|254|78|
7|7|106*|104*|117*|101*|102*|103*|106*|RC|AAA-|254|215|
7|7|106*|104*|117*|101*|102*|103*|106*|RC|AAB|254|215|
7|7|106*|104*|117*|101*|102*|103*|106*|RC|AAB+|254|215|
7|9|105*|118*|114*|113*|108*|110*|109*|107*|105*|RC|AAC|254|78|
7|9|105*|118*|114*|113*|108*|110*|109*|107*|105*|RC|AAC+|254|78|
7|4|108*|112*|111*|110*|RT|
7|4|118*|116*|115*|114*|RT|
Grazie per la collaborazione.
toreerot
24 Gennaio 2005
 0 -  0 - Inviato: 09 Novembre 2007 alle ore 18:09
Salve,
credo che il problema sia nelle linee tratteggiate. Non vengono riconosciute dal Pregeo come parte del fabbricato. Quindi se tu hai messo la superficie reale del fabbricato che comprende anche le verande, poi non corrisponde con la superficie dell'elaborazione.
Io di solito faccio così ed il catasto lo accetta: ingombro massimo del fabbricato, compreso di verande, con linea continua; linee tratteggiate quelle che stanno all'interno (nel tuo caso 108-110 e 114-118).
Ciao.
stellamay
23 Novembre 2005
 0 -  0 - Inviato: 12 Novembre 2007 alle ore 13:48
grazie per il chiarimento.
