/ Forum / PREGEO e DOCFA / PREGEO / errore su censuario
Autore errore su censuario
toniooo
01 Settembre 2003
Caserta
 0 -  0 - Inviato: 04 Agosto 2009 alle ore 19:39
Nel modello censuario seguente mi viene riportato l'errore:
la particella provvisoria ABB citata come originale non è stata costituita
il modello censuario è:
6|51FTP|016| |
6|O|2743 |000| | |000001118|SN| | |036|1 | |
6|S|2743 |000| | |000000000| | | |000| | |
6|C| |000|a |AAA |000000316|SN|A |ABA |000| | |
6|C| |000|b |AAB |000000227|SN|B |ABB |000| | |
6|C| |000|c |ABC |000000119|SN| | |000| | |
6|C| |000|d |ABD |000000104|SN| | |000| | |
6|C| |000|e |ABE |000000061|SN| | |000| | |
6|C| |000|f |AAF |000000019|SN|B |ABB |000| | |
6|C| |000|g |AAG |000000271|SN|F |ABF |000| | |
6|C| |000|h |AAH |000000001|SN|F |ABF |000| | |
6|O|2742 |000| | |000000190|SN| | |036|3 | |
6|S|2742 |000| | |000000000| | | |000| | |
6|C| |000|a |AAI |000000147|SN|B |ABB |000| | |
6|C| |000|b |AAL |000000024|SN|F |ABF |000| | |
6|C| |000|c |AAM |000000016|SN|A |ABA |000| | |
6|C| |000|d |AAN |000000003|SN|F |ABF |000| | |
6|M31FU|019| |
6|O|ABB |000| | |000000393|SN| | |036|1 | |
6|S|ABB |000| | |000000000| |SU|1799 |000| | |
6|O|1797 |000| | |000000029|SN| | |282| | |
6|S|1797 |000| | |000000000| |SU|1799 |000| | |
6|O|1798 |000| | |000000035|SN| | |282| | |
6|S|1798 |000| | |000000000| |SU|1799 |000| | |
6|O|1796 |000| | |000000058|SN| | |282| | |
6|S|1796 |000| | |000000000| |SU|1799 |000| | |
6|O|1608 |000| | |000000939|SN| | |282| | |
6|S|1608 |000| | |000000000| |SU|1799 |000| | |
6|O|2740 |000| | |000000747|SN| | |282| | |
6|S|2740 |000| | |000000000| |SU|1799 |000| | |
6|O|1799 |000| | |000000230|SN| | |282| | |
6|V|1799 |000| | |000000230|SN|CO|1797 |282| | |
6|D|1799 |000| | |000000230|SN|CO|1798 |282| | |
6|D|1799 |000| | |000000230|SN|CO|ABB |282| | |
6|D|1799 |000| | |000000230|SN|CO|1796 |282| | |
6|D|1799 |000| | |000000230|SN|CO|1608 |282| | |
6|D|1799 |000| | |000000230|SN|CO|2740 |282| | |
6|3SPC |003|*| |
6|O|1799 |000| | |000002142|SN| | |282| | |
6|S|1799 |000| | |000000000| | | |000| | |
6|C| |000|a |BBB |000002142|SN| | |282| | |
sapreste indicarmi come sistemare la cosa?
Antonio
pzero
08 Luglio 2003
Firenze - nome@cognome.it
 0 -  0 - Inviato: 05 Agosto 2009 alle ore 00:03
Creando, da qualche parte, la particella ABB prima di sopprimerla!
Comunque, e mi ripeto per l'ennesima volta, abbandonate l'ausiliario e fate le fusioni con i lotti, è più semplice, più chiaro e maggiormente a prova di errori
paolo
 0 -  0 - Inviato: 05 Agosto 2009 alle ore 10:08
Hai redatto il censuario facendo un po' di confusione con la numerazione delle particelle.
Usa progressivo assoluto
AAA
AAB
AAC
oppure progressivo per particella
AAA
AAB
ABA
ABB
ABC
ACA
ACB
ACC
Concordo con PZero sulla bellezza delle fusioni con i lotti.
Forse non ne avete mai avuto a che fare ma sono LEGGIBILI e SEMPLICI da applicare.
toniooo
01 Settembre 2003
Caserta
 0 -  0 - Inviato: 05 Agosto 2009 alle ore 11:05
Dove posso trovare informazioni in merito all'utilizzo dei lotti?
In effetti pensavo che dichiarando nelle righe tipo:
le varie particelle costiutite e appartenenti al lotto B - ABB, avessi già dichiarato la loro esistenza.
pzero
08 Luglio 2003
 0 -  0 - Inviato: 05 Agosto 2009 alle ore 13:03
Quando costituisci un lotto, devi usare un numero esistente o creato precedentemente.
Attenzione alla formazione dei lotti nel frazionamento.
E' possibile solo se le particelle hanno stessa qualità e classe.
Altrimenti usi mod. 26 o docte.
Per le fusioni nel 3spc, invece nessun problema se il lotto finale è un ente urbano.
informazioni sui lotti li trovi qui :
www.zeroni.it/servizio/manuale.pdf
è il vecchio manuale del db censuario del pregeo 7, quello che lo introduceva.
paolo
