/ Forum / PREGEO e DOCFA / PREGEO / compilazione MODELLO CENSUARIO TF + TM al NCEU
Argomento: compilazione MODELLO CENSUARIO TF + TM al NCEU
Mauree
30 Maggio 2006
 0 -  0 - Inviato: 28 Novembre 2014 alle ore 14:00
ho lo stesso problema di samsung..
le ho provate un po tutte anche io
qualcuno mi puo aiutare?
dove sbaglio?
6|51FTP|029| |
6|O|3048 |000| | |000005273|SN| | |047|02| |
6|S|3048 |000| | |000000000| | | |000| | |
6|C| |000|a |DDD |000004373|SN|D |AAA |000| | |
6|C| |000|b |EEE |000000892|SN| | |000| | |
6|C| |000|c |FFF |000000008|SN|E |BBB |000| | |
6|O|3055 |000| | |000000402|SN| | |047|02| |
6|S|3055 |000| | |000000000| | | |000| | |
6|C| |000|a |GGG |000000351|SN|D |AAA |000| | |
6|C| |000|b |HHH |000000051|SN| | |000| | |
6|O|3142 |000| | |000002643|SN| | |047|02| |
6|S|3142 |000| | |000000000| | | |000| | |
6|C| |000|a |III |000002642|SN|E |BBB |000| | |
6|C| |000|b |JJJ |000000001|SN| | |000| | |
6|O|3145 |000| | |000000106|SN| | |282| | |
6|V|3145 |000| | |000000058|SN| | |000| | |
6|C| |000|a |KKK |000000037|SN| | |000| | |
6|C| |000|b |LLL |000000011|SN| | |000| | |
6|O|3147 |000| | |000001029|SN| | |282| | |
6|V|3147 |000| | |000000954|SN| | |000| | |
6|C| |000|a |MMM |000000075|SN| | |000| | |
6|O|3151 |000| | |000001153|SN| | |047|02| |
6|S|3151 |000| | |000000000| | | |000| | |
6|C| |000|a |NNN |000000251|SN| | |000| | |
6|C| |000|b |OOO |000000339|SN|D |AAA |000| | |
6|C| |000|c |PPP |000000563|SN| | |000| | |
6|O|3153 |000| | |000002088|SN| | |282| | |
6|V|3153 |000| | |000001811|SN| | |000| | |
6|C| |000|a |QQQ |000000246|SN| | |000| | |
6|C| |000|b |RRR |000000031|SN| | |000| | |
6|3SPC |030|*| |
6|V|3145 |000| | |000000106|SN|A |3145 |282| | |
6|O|MMM |000| | |000000075|SN| | |282| | |
6|S|MMM |000| | |000000000| |A |3145 |000| | |
6|V|3147 |000| | |000001029|SN|B |3147 |282| | |
6|O|3143 |000| | |000000017|SN| | |047|02| |
6|S|3143 |000| | |000000000| |B |3147 |000| | |
6|O|3149 |000| | |000000118|SN| | |047|02| |
6|S|3149 |000| | |000000000| |B |3147 |000| | |
6|O|KKK |000| | |000000037|SN| | |282| | |
6|S|KKK |000| | |000000000| |B |3147 |000| | |
6|O|LLL |000| | |000000011|SN| | |282| | |
6|S|LLL |000| | |000000000| |B |3147 |000| | |
6|O|QQQ |000| | |000000246|SN| | |282| | |
6|S|QQQ |000| | |000000000| |B |3147 |000| | |
6|V|3153 |000| | |000002088|SN|C |3153 |282| | |
6|O|EEE |000| | |000000892|SN| | |047|2 | |
6|S|EEE |000| | |000000000| |C |3153 |000| | |
6|O|III |000| | |000000001|SN| | |047|2 | |
6|S|III |000| | |000000000| |C |3153 |000| | |
6|O|NNN |000| | |000000251|SN| | |047|2 | |
6|S|NNN |000| | |000000000| |C |3153 |000| | |
6|O|PPP |000| | |000000564|SN| | |047|2 | |
6|S|PPP |000| | |000000000| |F |CCC |000| | |
6|O|HHH |000| | |000000051|SN| | |047|2 | |
6|S|HHH |000| | |000000000| |F |CCC |000| | |
6|O|RRR |000| | |000000031|SN| | |282| | |
6|S|RRR |000| | |000000000| |F |CCC |000| |
Mauree
30 Maggio 2006
 0 -  0 - Inviato: 28 Novembre 2014 alle ore 14:13
avendo 9 particelle e non potendole mettere tutte in riga 0
anche leggendo i vari post sull'argomento del forum ho messo solo la particella 3048
e poi nella successiva riga 6 tutte le altre..
questo puo creare problemi al modello censuario?
Mauree
30 Maggio 2006
 0 -  0 - Inviato: 28 Novembre 2014 alle ore 14:17
SIMBA964
20 Marzo 2014 alle ore 17:05
in fede con DIO
 0 -  0 - Inviato: 28 Novembre 2014 alle ore 16:10
SIMBA964
in fede con DIO
 0 -  0 - Inviato: 28 Novembre 2014 alle ore 16:33
dove sbaglio?
6|51FTP|029| |
6|C| |000|a |DDD |000004373|SN|D |DDD |000| | |
6|C| |000|c |FFF |000000008|SN|E |FFF |000| | |
6|C| |000|a |GGG |000000351|SN|D |DDD |000| | |
6|C| |000|a |III |000002642|SN|E |FFF |000| | |
6|C| |000|b |OOO |000000339|SN|D |DDD |000| | |
6|3SPC |030|*| |
Salve prova a modificarlo con le correzioni in rosso, ovviamente nel disegno sviluppo futuro la tua particella AAA diventerà DDD e la tua BBB diventerà FFF.
[color=#ff0000]Facci sapere [/color]
[color=#ff0000]Saluti cordiali[/color]
Mauree
30 Maggio 2006
 0 -  0 - Inviato: 28 Novembre 2014 alle ore 16:46
niente da fare..come nel mio modello precedente me lo salva correttamente
e poi al momento della proposta finale mi dice che ci sono errori formali
le particelle 3143 e 3149 che non vengono frazionate ma solamente fuse nella 3147
è giusto che vadano solo nel modello mappale giusto?
Salvatore_B.
Juneau
 0 -  0 - Inviato: 28 Novembre 2014 alle ore 16:54
Se il censuario lo posti come immagine, vedi mio post del 08/09/2014 ore 21:10, potrei vedere se domani trovo il tempo di analizzarlo (sempre se ne trovo il tempo). Riportato in quel modo non riesco a leggerlo. La grafica delle mappe è perfetta (chiarissima).
SIMBA964
in fede con DIO
 0 -  0 - Inviato: 28 Novembre 2014 alle ore 17:12
Si è giusto fonderle con il mod mappale,
Con le modifiche che ti avevo suggerito a me funziona in ufficio, nessun errore formale.
Mauree
30 Maggio 2006
 0 -  0 - Inviato: 28 Novembre 2014 alle ore 17:14
Mauree
30 Maggio 2006
 0 -  0 - Inviato: 28 Novembre 2014 alle ore 17:18
Mauree
30 Maggio 2006
 0 -  0 - Inviato: 28 Novembre 2014 alle ore 17:19
pregeo sperimentale?
SIMBA964
in fede con DIO
 0 -  0 - Inviato: 28 Novembre 2014 alle ore 17:28
No pregeo 10.51
Controlla bene che la tua proposta sia conforme al modello integrato, controlla se hai eseguito lo stralcio in modo congruo.
Ma il problema te lo da quando vai a fare la predisposizione??
Mauree
30 Maggio 2006
 0 -  0 - Inviato: 28 Novembre 2014 alle ore 17:40
No pregeo 10.51
esatto..il modello censuario me lo fa salvare correttamente senza errori
ma quando faccio la predisposizione si blocca dandomi il messaggio che il modello censuario contiene errori formali
SIMBA964
in fede con DIO
 0 -  0 - Inviato: 28 Novembre 2014 alle ore 18:34
Carica il file che ti ho spedito, vediamo se funziona
ciao, Stefano
Salvatore_B.
Juneau
 0 -  0 - Inviato: 28 Novembre 2014 alle ore 18:46
ancora non ho visto il modello censuario.
guardando le mappe (attuale e stato fututo) mi chiedevo se non fosse meglio che la JJJ andasse alla nuova BBB, per avere i confini tra AAA, BBB e 3153 tutti con una sola linea (senza spezzata), sempre che lo stato dei luoghi non sia più modificabile.
per inserire tutte e 9 le particelle in riga 9 c'è un "trucco", che dopo anni che non mi capita ho simulato ora con Pregeo 10.5.1 per questo caso di mauro.
sarò ripetitivo, ma lo dico. hai controllato che le sup. e le qualità e classi del modello siano tutte imputate giuste? come da visure ed edm?
per le altre cose, aspettiamo che tu verifichi se ti funziona cosa ti ha mandato stefano.
