MODELLO CENSUARIO
COLLEGHI UN CONSIGLIO SUL CENSUARIO VISTO CHE MI COMPARE L’ERRORE SEGUENTE
IL LOTTO C CCC E’ CITATO UNA SOLA VOLTA NELLO SCHEMA
IL LOTTO D DD E’ CITATO UNA SOLA VOLTA NELLO SCHEMA
IL LOTTO D CCC E’ CITATO UNA SOLA VOLTA NELLO SCHEMA
IN PRATICA DEVO ACCORPARE PORZIONI DI AREE DERIVANTI DA FABBRICATO RURALE E PASSARE AD ENTE URBANO L E PARTICELLE CCC E DDD derivanti dalle particelle 128 di 88 mq e 126 di 150mq
LA PARTICELLE 128 DI 88 MQ E’ COSI’ DIVISA
86 MQ DA MANDARE A CCC
2 MQ DA MANDARE DDD
LA PARTICELLA 126 DI 150 MQ E’ COSI’ DIVISA
30 MQ BBB INCOLTO
111MQ EEE DA MANDARE ALLA CCC
9 MQ FFF DA MANDARE ALLA DDD
E ALLA FINE CON L’AUSILIARIO CAMBIARE DI COLTURA LA PARTICELLA BBB AD INCOLTO PRODUTTIVO
ECCO COME STO PROCEDENDO SAPENDO CHE LE PARTICELLE DEFINITIVE SONO BBB (INCOLTO) DDD E CCC FABBRICATO:
3SPC con lo scopo di passare all’urbano le superfici
|O|128 |000| | |000000088|SN| | |279| | |
6|S|128 |000| | |000000000| | | |000| | |
6|C| |000|a |CCC |000000086|SN|C |CCC |282| | |
6|C| |000|b |DDD |000000002|SN|D |DDD |282| | |
6|51FTP|005|*| |
6|O|126 |000| | |000000150|SN| | |279| | |
6|S|126 |000| | |000000000| | | |000| | |
6|C| |000|a |BBB |000000030|SN| | |000| | |
6|C| |000|b |EEE |000000111|SN|C |CCC |000| | |
6|C| |000|c |FFF |000000009|SN|D |DDD |000| | |
6|M31FU|002| |
6|O|BBB |000| | |000000030|SN| | |279| | |
6|V|BBB |000| | |000000030|SN| | |101|1 | |
GRAZIA A CHIUNQUE SAPPIA AIUTARMI
