/ Forum / PREGEO e DOCFA / PREGEO 10.6.0 / SEMIASSE ELLISSE ERRORE
Autore SEMIASSE ELLISSE ERRORE
geobonar
23 Febbraio 2013 alle ore 09:34
 0 -  0 - Inviato: 01 Marzo 2019 alle ore 19:08
Ciao a tutti, sono alle prese con un TM per l'inserimento in mappa di una piscina. Ho eseguito un rilievo gps dei punti del contorno piscina, del PF 06, mentre i PF 14 e PF15 sono stati determinati per intersezione dai punti 141/142 e 151/152. Pregeo segnala che il semiasse dell'ellisse d'errore č 0.211>0,10. Come posso risolvere? Un grazie a chi mi vorrā aiutare. Posto il libretto e l'elaborazione.
LIBRETTO
0|15022019|1|I782|9050|2682,2683,2684,2685,2331|
9|203|10|20|1617940|PREGEO 10.00-G,APAG 2.08|FM|Nota: GPS TRIBLE R6|
1|100|4400914.93,816451.98,4528894.38|0.000|Punto Iniziale Baseline:chiodo|
6|L2|15022019-13:33|15022019-17:17|RTK|PDOP=2|
2|200|2.628,-1.146,-2.545|0.00450016,-0.00113215,0.00095941,0.00048960,-0.00005440,0.00148344|PDOP=4|0.000|
2|101|0.040,13.055,-2.439|0.00110702,-0.00004368,0.00105777,0.00032022,-0.00009388,0.00169155|PDOP=2|0.000|
2|102|-0.506,23.640,-3.576|0.00094948,-0.00006555,0.00003822,0.00024689,0.00049669,0.00200972|PDOP=6|0.000|
2|104|3.908,16.775,-6.803|0.00076314,0.00008023,0.00049992,0.00016955,0.00013359,0.00064028|PDOP=2|0.000|
2|105|4.069,12.732,-6.355|0.00057259,0.00012991,0.00053812,0.00021710,0.00012146,0.00094955|PDOP=2|0.000|
2|106|3.403,23.435,-7.654|0.00044561,0.00006439,0.00034592,0.00021625,0.00013874,0.00085574|PDOP=1|0.000|
2|108|1.779,23.494,-6.041|0.00196693,0.00028985,0.00131078,0.00052491,0.00036020,0.00175059|PDOP=3|0.000|
2|PF06/9050/I782|-2.633,28.904,0.069|0.00111966,0.00017163,0.00082799,0.00093851,-0.00024961,0.00146577|PDOP=2|0.000|
2|151|160.022,109.096,-152.411|0.00037179,0.00003455,0.00017437,0.00008872,0.00003147,0.00029139|PDOP=1|0.000|
2|152|162.389,107.395,-154.423|0.00059870,0.00025782,-0.00009423,0.00033325,-0.00024005,0.00066412|PDOP=2|0.000|
2|141|-76.113,-148.050,119.270|0.00040449,0.00003112,0.00021470,0.00007124,0.00004307,0.00027600|PDOP=2|0.000|
2|142|-79.850,-143.582,121.626|0.00043345,0.00004737,0.00022453,0.00007542,0.00004925,0.00026934|PDOP=2|0.000|
4|151|152|-30|
5|PF15/9050/I782|4.011|0|
4|152|151|30|
5|PF15/9050/I782|3.135|0|
4|151|1.200|
5|PF15/9050/I782|1.200|
4|141|142|-30|
5|PF14/9050/I782|21.768|0|
4|142|141|30|
5|PF14/9050/I782|24.923|0|
4|141|1.200|
5|PF14/9050/I782|1.200|
8|PF14/9050/I782|5042999.665000|1617781.783000|64|SPIG. S/E (NCTR FG.5 N.177)|
8|PF14/9050/I782|9999.000000|04|QUOTA STRADA|
8|PF15/9050/I782|5042604.429000|1618017.050000|52|SPIG. N/O (NCTR FG.6 N.108)|
8|PF15/9050/I782|9999.000000|04|QUOTA SOMMITA TERRAZZO|
8|PF06/9050/I782|5042834.379000|1617964.929000|62|SPIG. SUD (NCTR FG.5 N.187)|
8|PF06/9050/I782|9999.000000|04|QUOTA TESTA MURETTO (A 2.10 MT DA TERRA )|
6|DELIMTAZIONE CONTORNO PISCINA|
7|7|101|102|108|106|104|105|101|RT|
6|IL PRESENTE TIPO DI AGGIORNAMENTO E' STATO REDATTO PER INTRODURRE IN |6|MAPPA UNA PISCINA INTERRATA NON COPERTA. LE PARTICELLE |6|2682,2683,2684,2685 SONO ACCORPATI ALLA 2331 GIA' ENTE URBANO. |
ELABORAZIONE PREGEO:
Risultati Elaborazione
rototraslazione effettuata sulla posizione TAF dei 3 PF rilevati
dello stesso sistema dell'oggetto del rilievo (< SCONOSCIUTO >)
parametri adattamento : rotazione 394.6829 gc
parametri adattamento : coeff. scala 1.0083 unita'
Compensazione Planimetrica
Rilievo eseguito con un numero minimo di osservazioni
Ellissi ed s.q.m.sono calcolati in funzione
delle precisioni strumentali dichiarate
s.q.m. dell'unita' di peso a priori 0.10712
s.q.m. dell'unita' di peso a posteriori 0.01580
s.q.m. dell'unita' di peso interna 0.10712
s.q.m. dell'unita' di peso esterna 0.14752
Numero di cicli di compensazione 9
Valore del massimo semiasse maggiore delle ellissi d'errore = 0.211> 0.100 m corrispondente al punto PF14/9050/I782
Punti della Rete
nome nord sqm est sqm semiasseMax semiasseMin inclinazione
100 5042834.509 +/-0.011 1617924.600 +/-0.014 0.015 0.010 182.634
PF06/9050/I782 5042834.889 +/-0.021 1617953.551 +/-0.016 0.021 0.015 82.853
PF15/9050/I782 5042604.224 +/-0.021 1618021.644 +/-0.006 0.022 0.002 116.654
PF14/9050/I782 5042989.653 +/-0.197 1617761.719 +/-0.079 0.211 0.027 76.873
200 5042830.919 +/-0.047 1617923.269 +/-0.028 0.050 0.023 77.130
151 5042608.068 +/-0.023 1618020.501 +/-0.045 0.048 0.015 25.115
152 5042605.065 +/-0.041 1618018.624 +/-0.038 0.050 0.025 53.471
141 5042980.027 +/-0.031 1617781.236 +/-0.038 0.046 0.015 41.615
142 5042984.099 +/-0.030 1617786.008 +/-0.039 0.046 0.016 39.713
Punti di Dettaglio
101 5042832.079 +/-0.017 1617937.654 +/-0.023 0.024 0.016 183.033
102 5042831.108 +/-0.036 1617948.265 +/-0.017 0.036 0.017 107.043
104 5042826.073 +/-0.012 1617941.081 +/-0.012 0.016 0.002 151.060
105 5042826.487 +/-0.013 1617937.033 +/-0.015 0.016 0.012 168.452
106 5042825.482 +/-0.012 1617947.786 +/-0.014 0.019 0.005 152.817
108 5042827.764 +/-0.021 1617947.963 +/-0.022 0.023 0.019 159.375
Correzioni d'orientamento e relativi sqm
nome stazione N. ripetiz. Correzione[GC] sqm[CC]
100 0 395.05974 +/-198.82
151 0 181.60471 +/-7965.30
152 0 117.29456 +/-11469.48
141 0 329.17146 +/-6317.42
142 0 314.31191 +/-5598.41
Mutue Distanze tra i Punti Fiduciali
Coppia PF dalla TAF Misurata sqm diff.
PF06/9050/I782-PF15/9050/I782 235.783 240.505 0.040 -4.722
PF06/9050/I782-PF14/9050/I782 246.702 246.478 0.076 +0.224
PF15/9050/I782-PF14/9050/I782 459.959 464.884 0.125 -4.925
Compensazione Altimetrica
s.q.m. dell'unita' di peso a priori 0.00100
s.q.m. dell'unita' di peso a posteriori 0.02536
s.q.m. dell'unita' di peso interna 0.00100
s.q.m. dell'unita' di peso esterna 25.36351
Numero di cicli di compensazione 3
Elenco dei soli punti per i quali la quota e' calcolabile
calcolo eseguito in base all'inquadramento altimetrico effettuato
sulle quote dei seguenti Punti Fiduciali definite nella TAF
PF06/9050/I782 quota=9999.00
PF15/9050/I782 quota=9999.00
PF14/9050/I782 quota=9999.00
Punti della Rete
nome quota sqm
100 -6.149 +/- 0.0150
PF06/9050/I782 -4.220 +/- 0.0419
PF15/9050/I782 9.261 +/- 0.0214
PF14/9050/I782 7.618 +/- 0.0219
151 9.261 +/- 0.0214
141 7.618 +/- 0.0219
Punti di Dettaglio
nome quota sqm
200 -6.302 +/- 0.0645
101 -6.194 +/- 0.0529
102 -6.029 +/- 0.0447
104 -6.168 +/- 0.0404
105 -6.254 +/- 0.0417
106 -6.272 +/- 0.0380
108 -6.232 +/- 0.0602
152 9.239 +/- 0.0310
142 7.296 +/- 0.0318
Dislivelli tra i Punti Fiduciali
PF06/9050/I782-PF15/9050/I782 ---------- 13.481 0.055 -----
PF06/9050/I782-PF14/9050/I782 ---------- 11.838 0.055 -----
PF15/9050/I782-PF14/9050/I782 ---------- -1.643 0.038 -----
Elenco Distanze e Dislivelli tra i Punti Fiduciali riferiti da
questo libretto determinate da atti di aggiornamento giā trattati
| Coppia PF | distanza | sqm |dislivello | sqm | diff.|
| PF06/9050/I782-PF15/9050/I782 | 240.505|+0.040| 13.481|+0.055|
|Tipo prot. 36200 del 2006| 240.505|+0.014|-----------|------|+0.000|
|Tipo prot. 346489 del 2007| 240.505|+0.015|-----------|------|+0.000|
|Tipo prot. 206352 del 2006| 240.495|+0.003|-----------|------|+0.010|
|Tipo prot. 97213 del 2004| 240.380|+0.004|-----------|------|+0.125|
|Tipo prot. 287899 del 2008| 240.481|+0.011|-----------|------|+0.024|
|Tipo prot. 177439 del 2003| 240.380|+0.005|-----------|------|+0.125|
|Tipo prot. 94743 del 2002| 240.485|+0.005|-----------|------|+0.020|
|Tipo prot. 256242 del 2000| 240.475|+0.005|-----------|------|+0.030|
|Tipo prot. 347624 del 2006| 240.496|+0.004|-----------|------|+0.009|
|Tipo prot. 290789 del 2004| 240.386|+0.004|-----------|------|+0.119|
|Tipo prot. 290857 del 2004| 240.386|+0.004|-----------|------|+0.119|
|Tipo prot. 214747 del 2017| 240.518|+0.018|-----------|------|-0.013|
|Tipo prot. 214757 del 2017| 240.518|+0.018|-----------|------|-0.013|
| PF06/9050/I782-PF14/9050/I782 | 246.478|+0.076| 11.838|+0.055|
|Tipo prot. 230759 del 2014| 246.476|+0.001|-----------|------|+0.002|
|Tipo prot. 165529 del 2018| 246.447|+0.019|-----------|------|+0.031|
|Tipo prot. 125359 del 2016| 246.423|+0.001|-----------|------|+0.055|
|Tipo prot. 316627 del 2006| 246.404|+0.011|-----------|------|+0.074|
|Tipo prot. 154118 del 2005| 246.406|+0.006|-----------|------|+0.072|
|Tipo prot. 83152 del 2005| 246.544|+0.004|-----------|------|-0.066|
|Tipo prot. 275603 del 2005| 246.544|+0.004|-----------|------|-0.066|
|Tipo prot. 245597 del 2002| 246.502|+0.007|-----------|------|-0.024|
|Tipo prot. 38848 del 1997| 246.485|+0.019|-----------|------|-0.007|
|Tipo prot. 288833 del 2004| 246.494|+0.000|-----------|------|-0.016|
| PF14/9050/I782-PF15/9050/I782 | 464.884|+0.125| -1.643|+0.038|
|Tipo prot. 135215 del 2008| 464.802|+0.014|-----------|------|+0.082|
|Tipo prot. 466610 del 2004| 464.920|+0.015|-----------|------|-0.036|
Proprietā e Intestazione Catastale (di geoalfa del 31/01/2026 19:25:10)
