/ Forum / PREGEO e DOCFA / G.P.S. / ERRORI PREGEO 10
Autore ERRORI PREGEO 10
montanatony86
26 Febbraio 2013 alle ore 11:16
 0 -  0 - Inviato: 09 Aprile 2014 alle ore 08:55
ciao a tutti.. ho un problema con questo tipo mappale su pregeo 10.. Premetto che la tipologia selezionata č corretta, i miei problemi sorgono una volta creata la proposta di aggiornamento.. come ho presentato la proposta in catasto (oppure importandola in un altro pc di mia proprieta) mi da subito errori nel censuario ( redatto da me manualmente), se provo a fare Crea censuario da Pda, mi dice : Valore del massimo semiasse maggiore delle ellissi d'errore = 0.242> 0.100 m
corrispondente al punto 109.. e nn me lo fa creare..
VI POSTO IL LIBBRETTO DELLE MISURE, CONTROLLI DI APPROVABILITA'...
0|05042014|1|B314A|0280|819|XXXXXXXXXXX|XXXXXXXXXXXX|XXXXXXXXXXX|
9|6|10|20|-49643|PREGEO 10.00-G,Stda 1.13|14|gps stonex s9gnss|
6|DettaglioTipoAgg=(14) - TM - Inserim. nuovo fabbricato e scorporo di corte (stralcio di corte)|
1|100|4843012.43,726940.48,4072632.25|1.560|chiodo su asfalto|
6|L2|03042014-08:23|03042014-09:35|RTK|PDOP=1|
2|101|-6.700,-3.730,9.511|0.02201497,0.00013289,0.00023001,0.01164797,0.00007772,0.01425246|PDOP=3|2.000|SPIGOLO LOTTO|
2|102|-9.396,-8.829,13.589|0.01068805,0.00001414,0.00004568,0.00473810,0.000009900,0.01015784|PDOP=2|2.000|SPIGOLO FABBR|
2|103|-16.564,-22.378,24.460|0.01200163,0.00002448,0.00006558,0.00532527,0.00001741,0.00845681|PDOP=2|2.000|SPIGOLO FABBR|
2|104|-54.425,-93.133,81.491|0.01668937,0.00006312,0.00014927,0.00720042,0.00004346,0.01228723|PDOP=3|2.000|SPIGOLO LOTTO|
2|105|-26.986,-128.596,55.188|0.01296303,0.00001114,0.00008710,0.00600990,0.000009500,0.00992864|PDOP=2|2.000|SPIGOLO LOTTO|
2|106|20.502,-38.720,-16.508|0.01549220,0.00002254,0.00012836,0.00676147,0.00001501,0.01162409|PDOP=2|2.000|SPIGOLO LOTTO|
2|107|0.997,-13.610,2.144|0.01627879,0.00005875,0.00013500,0.00740154,0.00003862,0.01130284|PDOP=2|2.000|SPIGOLO FABB|
2|108|-1.849,-18.312,5.211|0.01834962,0.00002194,0.00017393,0.00878348,0.00001936,0.01345677|PDOP=2|2.000|SPIGOLO FABB|
2|109|-3.139,-16.699,6.462|0.02872226,0.00001103,0.00015737,0.02821167,0.000008850,0.03574590|PDOP=2|2.000|SPIGOLO FABB|
2|110|-3.607,-17.261,6.955|0.01882860,-0.00007534,0.00014702,0.00940284,-0.00002241,0.01097055|PDOP=2|2.000|SPIGOLO FABB|
2|111|-6.734,-12.509,10.986|0.01838794,0.000007730,0.00013793,0.00886160,-0.00002920,0.02040090|PDOP=2|2.000|SPIGOLO FABB|
2|112|-7.201,-13.364,11.669|0.01788884,0.00001207,0.00014381,0.00792277,0.000003920,0.01797097|PDOP=2|2.000|SPIGOLO FABB|
2|113|-5.972,-15.285,10.086|0.01865563,0.00003787,0.00023526,0.00757842,0.00002817,0.01668929|PDOP=2|2.000|SPIGOLO FABB|
2|114|-11.887,-26.166,18.318|0.02258699,-0.00003087,0.00025486,0.01021327,-0.000001090,0.01539169|PDOP=2|2.000|SPIGOLO FABB|
2|115|-13.036,-24.607,19.791|0.02258699,-0.00003087,0.00025486,0.01021327,-0.000001090,0.01539169|PDOP=2|2.000|SPIGOLO FABB|
2|116|-14.276,-26.349,21.125|0.02476841,0.000003780,0.00025030,0.01143413,0.000006870,0.01808900|PDOP=2|2.000|SPIGOLO FABB|
2|117|-46.804,-116.780,76.474|0.00991191,0.00001298,0.00004971,0.00512505,0.000009120,0.00768433|PDOP=1|2.000|SPIGOLO LOTTO|
2|118|-58.436,-100.307,87.613|0.01606651,0.00014674,0.00010558,0.01566156,0.00004799,0.00975596|PDOP=2|2.000|SPIGOLO LOTTO|
2|119|-18.797,-129.552,45.793|0.01465345,0.00004195,0.00014516,0.00738122,0.00002731,0.01400675|PDOP=2|2.000|SPIGOLO LOTTO|
2|120|-9.295,-110.673,31.301|0.00871670,0.00001980,0.00003308,0.00508342,0.00001014,0.00606786|PDOP=1|2.000|SPIGOLO LOTTO|
2|121|-76.200,-170.965,117.604|0.02639867,0.00005774,0.00012870,0.01120977,-0.00010371,0.02315744|PDOP=1|2.000|SPIGOLO LOTTO|
2|122|-15.762,-135.762,40.082|0.02639867,0.00005774,0.00012870,0.01120977,-0.00010371,0.02315744|PDOP=1|2.000|SPIGOLO LOTTO|
2|123|-6.677,-116.814,25.716|0.02639867,0.00005774,0.00012870,0.01120977,-0.00010371,0.02315744|PDOP=1|2.000|SPIGOLO LOTTO|
2|124|-21.099,-29.397,27.826|0.02639867,0.00005774,0.00012870,0.01120977,-0.00010371,0.02315744|PDOP=1|2.000|SPIGOLO LOTTO|
2|125|-54.878,-107.900,81.457|0.02639867,0.00005774,0.00012870,0.01120977,-0.00010371,0.02315744|PDOP=1|2.000|SPIGOLO LOTTO|
2|126|-44.351,-72.977,63.017|0.02639867,0.00005774,0.00012870,0.01120977,-0.00010371,0.02315744|PDOP=1|2.000|SPIGOLO LOTTO|
2|PF29/0280/B314A|40.821,-105.089,-27.622|0.00938831,0.000005160,0.00004696,0.00474375,-0.00003000,0.00748673|PDOP=2|2.000|spigolo recinzione|
2|PF07/0280/B314A|-102.898,-204.509,158.445|0.01605697,0.00003487,0.00012316,0.00959180,0.000003730,0.01250768|PDOP=2|2.000|spigolo pilastro|
2|PF18/0280/B314A|-53.514,92.160,46.823|0.01489247,0.000005880,0.00012870,0.00856234,-0.00001069,0.01474540|PDOP=1|2.000|triplice di confine|
2|PF04/0280/B314A|88.369,90.025,-119.028|0.02639867,-0.00005774,0.00049767,0.01120977,-0.00010371,0.02315744|PDOP=2|2.000|spigolo recinzione|
6|CONTORNO LOTTO|
7|4|118|125|117|121|NC|
7|4|122|119|120|123|NC|
6|CONTORNO AREA URBANA|
7|10|101|102|103|124|RC|
7|0|126|104|NC|
7|0|105|106|107|101|RC|
6|CONTORNO FABBRICATO|
7|6|107|108|109|110|111|102|RC|
7|7|111|112|113|114|115|116|103|RC|
6|Lo schema del rilievo ha interessato i punti fiduciali: n.4,7,29 e 12 |
6|del foglio 28 in Cabras. Le operazioni di misura sono state eseguite |
6|con rilievo GPS in modalita'RTK. Dalle risultanze dei dei dati |
6|elaborati e' emersa una lieve discordanza tra le misurate e la TAF per |
6|cui il sottoscritto dichiara la conformita' del presente rilievo. Non |
6|č stato possibile chiudere il contorno della particella 819 in quanto |
6|non materializzato.
Risultati Elaborazione
Trattamento di Atto di Aggiornamento di tipologia : 14 ->
TM - Inserimento nuovo fabbricato e scorporo di corte (stralcio di corte)
PF29/0280/B314A Trovato nella TAF
PF07/0280/B314A Trovato nella TAF
PF18/0280/B314A Trovato nella TAF
PF04/0280/B314A Trovato nella TAF
In base all'est media inserita (-49643)
il calcolo prosegue nella rappresentazione cartografica Cassini-Soldner:
rototraslazione effettuata sulla posizione TAF dei 4 PF rilevati
dello stesso foglio citato nella riga 0
parametri adattamento : rotazione 0.2902 gc
parametri adattamento : coeff. scala 1.0011 unita'
Compensazione Planimetrica
Rilievo eseguito con un numero minimo di osservazioni
Ellissi ed s.q.m.sono calcolati in funzione
delle precisioni strumentali dichiarate
s.q.m. dell'unita' di peso a priori 0.22227
s.q.m. dell'unita' di peso a posteriori 0.08569
s.q.m. dell'unita' di peso interna 0.22227
s.q.m. dell'unita' di peso esterna 0.38553
Numero di cicli di compensazione 3
Valore del massimo semiasse maggiore delle ellissi d'errore = 0.242> 0.100 m corrispondente al punto 109
Correzioni d'orientamento e relativi sqm
nome stazione N. ripetiz. Correzione[GC] sqm[CC]
100 0 0.29022 +/-203.58
Mutue Distanze tra i Punti Fiduciali
Coppia PF dalla TAF Misurata sqm diff.
PF29/0280/B314A-PF07/0280/B314A 255.800 255.264 0.138 +0.537
PF29/0280/B314A-PF18/0280/B314A 231.283 230.969 0.128 +0.314
PF29/0280/B314A-PF04/0280/B314A 221.154 220.647 0.160 +0.507
PF07/0280/B314A-PF18/0280/B314A 320.208 320.796 0.153 -0.588
PF07/0280/B314A-PF04/0280/B314A 448.168 447.576 0.178 +0.592
PF18/0280/B314A-PF04/0280/B314A 218.961 218.268 0.175 +0.693
Compensazione Altimetrica
s.q.m. dell'unita' di peso a priori 0.00100
s.q.m. dell'unita' di peso a posteriori 0.10135
s.q.m. dell'unita' di peso interna 0.00100
s.q.m. dell'unita' di peso esterna 101.35487
Elenco dei soli punti per i quali la quota e' calcolabile
Dislivelli tra i Punti Fiduciali
PF29/0280/B314A-PF07/0280/B314A -1.600 -0.846 0.154 -0.754
PF29/0280/B314A-PF18/0280/B314A 0.000 -1.291 0.154 +1.291
PF29/0280/B314A-PF04/0280/B314A -1.779 -0.413 0.185 -1.366
PF07/0280/B314A-PF18/0280/B314A 1.600 -0.445 0.173 +2.045
PF07/0280/B314A-PF04/0280/B314A -0.179 0.433 0.201 -0.612
PF18/0280/B314A-PF04/0280/B314A -1.779 0.878 0.201 -2.657
Verifica dell'inquadramento effettuata sulla posizione cartografica TAF dei 4 PF
rilevati dal Libretto
parametri dell'Inquadramento Cartografico : rotazione 399.8122 gc
parametri dell'Inquadramento Cartografico : coeff. scala cartografico 1.0105 unita'
Punto Fiduciale PF07/0280/B314A: scarto 3.39 > distorsione 1.50 m tra la posizione rilevata e quella cartografica
Punto Fiduciale PF18/0280/B314A: scarto 3.66 > distorsione 1.50 m tra la posizione rilevata e quella cartografica
Punto Fiduciale PF04/0280/B314A: scarto 1.67 > distorsione 1.50 m tra la posizione rilevata e quella cartografica
Attenzione la particella BBB dichiarata nel modello con superficie reale non trova corispondenza
con poligoni chiusi rilevati nel libretto
da esito positivo e mi fa continuare a predisporre l' atto...
AIUTATEMI PER FAVORE STO USCENDO FUORI DI TESTA
studiotopo
Ing. Oliveri
20 Gennaio 2005
Reggio Calabria
 0 -  0 - Inviato: 09 Aprile 2014 alle ore 10:24
Salve.
Ho elaborato il tuo libretto.
Il valore del massimo semiasse maggiore delle ellissi d'errore non riguarda solo il punto 109, ma tutti i punti.
Per ogni singolo punto rilevato, azzera le matrici di varianza e covarianza, visto che la stazione base (emanazione del rilievo) si trova nelle imnmediate vicinanze dell'oggeto del rilievo o meglio all'interno del triangolo fiduciale.
Stefano Oliveri
montanatony86
 0 -  0 - Inviato: 09 Aprile 2014 alle ore 11:26
grazie stefano olivieri ora ho rielaborato il tutto e nn ho piu problemi con i punti..
al momento di fare gli ulteriori controlli di approvabilitā mi appare questa schermata
CON ESITO NEGATIVO.. DA COSA DIPENDE ?? PERCHE NN MI FA ANDARE AVANTI??
GRAZIE ANTICIPATAMENTE
ANTONIO MANCA
montanatony86
 0 -  0 - Inviato: 09 Aprile 2014 alle ore 11:27
SCUSA HO SBAGLIATO IL TUO COGNOME...
studiotopo
Ing. Oliveri
20 Gennaio 2005
Reggio Calabria
 0 -  0 - Inviato: 09 Aprile 2014 alle ore 11:40
ANTONIO MANCA
Per quanto riguarda i PF, sei fuori tolleranza rispetto alla TAF, verifica se ci sono delle misurate tra la coppia dei PF utilizzati e confrontale con le tue misurate (dovresti rientrare all'interno della tolleranza).
Per quanto riguarda la particella BBB, hai creato un contorno chiuso (riga 7), senza indicare nella stessa riga l'identificativo della particella madre e derivata.
Guida Pregeo - 6.1.14 DESCRIZIONE DEI CONTORNI (RIGA 7)
Stefano Oliveri
montanatony86
 0 -  0 - Inviato: 09 Aprile 2014 alle ore 13:51
grazie ora ho risulto tutto.. riguardo all' errore sulla particella bbb, provavo a forzare il censuario.. ho risolto cambiando nel censuario da SR a SN.. pur essendo bbb una particella da me misurata interamente... ora la pratica č ok!!!! grazie mille
