/ Forum / PREGEO e DOCFA / PREGEO / Errore PREGEO
Autore Errore PREGEO
GianlucaSuppa
Gianluca Suppa
05 Settembre 2017 alle ore 15:29
Domodossola
 0 -  0 - Inviato: 21 Ottobre 2020 alle ore 23:23
Buonasera a tutti, sono disperato su un benedetto frazionamento perchè ho un problema con sto santo errore di ellissi..
C'è qualcuno che può aiutarmi per piacere?
Vi lascio di seguito il libretto. Grazie a chi risponderà
0|10212020|45053|H033|0590|495|BRAITO NORMA|GEOMETRA|VERBANO CUSIO OSSOLA|
9|792|10|20|11600|10.00-G,APAG 2.03,APAG 2.03|FR|Nota :|
1|100|4382807.52,638314.24,4574692.80|2.000|Base GPS [WGS84-ETRF2000]|
6|L2|17102020-09:40|17102020-10:40|RTK|PDOP=3|
2|101|-13217.391,3468.473,12650.042|0.000606040,0.000204750,0.000135610,0.000366890,0.000146230,0.000384410|PDOP=1|2.000|Punto appoggio|
2|102|-13217.209,3461.134,12650.039|0.000508220,0.000171200,0.000113630,0.000307030,0.000122400,0.000322450|PDOP=1|2.000|Punto appoggio|
2|103|-13220.555,3463.809,12653.376|0.000254860,0.000043580,0.000055890,0.000171710,0.000030720,0.000186960|PDOP=2|2.000|Punto appoggio|
2|104|-13221.963,3468.423,12654.344|0.000537750,0.000180680,0.000120150,0.000324260,0.000129300,0.000341250|PDOP=2|2.000|Punto appoggio|
2|105|-13221.933,3474.329,12654.209|0.000508220,0.000171200,0.000094590,0.000307030,0.000102560,0.000252250|PDOP=2|2.000|Punto appoggio[VRS]|
2|106|-13218.991,3474.486,12651.103|0.000490960,0.000168940,0.000114300,0.000309110,0.000137230,0.000384990|PDOP=2|2.000|Punto appoggio|
2|107|-13218.911,3472.322,12651.134|0.002160680,0.000757970,0.000489810,0.001339240,0.000532800,0.001360630|PDOP=2|2.000|Punto appoggio|
2|108|-13218.604,3472.277,12650.825|0.001388550,0.000497980,0.000318070,0.000869920,0.000346200,0.000868180|PDOP=2|2.000|Punto appoggio|
2|109|-13218.318,3469.909,12650.821|0.001388550,0.000497980,0.000318070,0.000869920,0.000346200,0.000868100|PDOP=2|2.000|Punto appoggio|
2|110|-13210.019,3469.494,12643.723|0.000920590,0.000389490,0.000246100,0.000654540,0.000303190,0.000657800|PDOP=3|2.000|Punto appoggio|
2|111|-13209.535,3475.825,12644.468|0.000407520,0.000149400,0.000094590,0.000257240,0.000102560,0.000252250|PDOP=1|2.000|Punto appoggio|
2|112|-13216.842,3475.725,12651.025|0.000490960,0.000168940,0.000114300,0.000309110,0.000137230,0.000384990|PDOP=2|2.000|Punto Ausiliario|
2|113|-13225.417,3468.496,12657.562|0.000486340,0.000178440,0.000112980,0.000306870,0.000122380,0.000300540|PDOP=2|2.000|Punto appoggio|
2|114|-13226.603,3467.190,12658.824|0.000702820,0.000268820,0.000169380,0.000451900,0.000181080,0.000433010|PDOP=2|2.000|Punto appoggio|
2|115|-13226.638,3465.540,12659.592|0.000490000,0.000180000,0.000110000,0.000310000,0.000120000,0.000300000|PDOP=3|2.000|Punto appoggio|
2|116|-13220.422,3474.386,12652.752|0.000919423,0.000349052,0.000230482,0.000619458,0.000276224,0.000654201|PDOP=2|2.000|Punto appoggio|
2|117|-12676.013,3554.784,13223.623|0.001388550,0.000497980,0.000318070,0.000869920,0.000346200,0.000868100|PDOP=3|2.000|dividente|
2|118|-12675.981,3547.481,13223.708|0.001388550,0.000497980,0.000318070,0.000869920,0.000346200,0.000868180|PDOP=3|2.000|dividente|
2|119|-12673.406,3542.611,13221.713|0.002160680,0.000757970,0.000489810,0.001339240,0.000532800,0.001360630|PDOP=3|2.000|Dividente|
2|120|-12706.132,3445.911,13249.261|0.000490960,0.000168940,0.000114300,0.000309110,0.000137230,0.000384990|PDOP=3|2.000|Picchetto|
2|121|-12707.225,3445.835,13250.286|0.000508220,0.000171200,0.000094590,0.000307030,0.000102560,0.000252250|PDOP=3|2.000|Picchetto|
2|122|-12528.445,3460.381,13073.176|0.000537750,0.000180680,0.000120150,0.000324260,0.000129300,0.000341250|PDOP=3|2.000|Picchetto|
2|123|-12527.376,3460.454,13072.126|0.000606040,0.000204750,0.000135610,0.000366890,0.000146230,0.000384410|PDOP=3|2.000|Picchetto|
2|PF02/0590/H033|-13251.364,3366.670,12680.669|0.000254860,0.000043580,0.000055890,0.000171710,0.000030720,0.000186960|PDOP=3|2.000|Spigolo fabbricato|
2|PF03/0590/H033|-13069.502,3381.414,12500.278|0.000508220,0.000171200,0.000113630,0.000307030,0.000122400,0.000322450|PDOP=2|2.000|Spigolo fabbricato|
6|Iperdeterminazione PF|
4|120|121|0|
5|PF02/0590/H033|3|0|
4|122|123|0|
5|PF03/0590/H033|3|0|
6|Linea Frazionamento|
7|3|117|118|119|RC|
8|112|-0.411|6.137|50|[P.A.] PUNTO AUSILIARIO|
8|PF03/0590/H033|91961.460000|11495.026000|52|SPIGOLO NORD FABBRICATO|
8|PF03/0590/H033|9999.000000|04|SOMMITA RIVESTIMENTO IN PIETRA|
8|PF02/0590/H033|92217.617000|11505.917000|52|SPIGOLO S.O. FABBRICATO|
8|PF02/0590/H033|9999.000000|04|SOMMITA ZOCCOLO IN PIETRA|
6|Il rilievo e' stato eseguito unicamente con strumentazione satellitare,|
6|tramite l'ausilio di Rover GPS. Il punto n.105 e' identificato come |
6|Stazione Virtuale, artificio necessario per una corretta elaborazione |
6|del tipo, in quanto la stazione base GPS di riferimento risulta ad una |
6|distanza fuori tolleranza massima. Rilievo conforme alle disposizioni |
6|delle circolare vigenti. Si e' dovuto procedere ad individuare un |
6|Punto Ausiliario (punto 112) in quanto non e' presente la monografia |
6|del PF01/0600/H033 ed essendo contro montagna non si e' potuto |
6|istituire un nuovo PF non avendo punto fissi affidabili. Tecnico |
6|Redattore: Geom. Norma Braito Via Rodis n. 7 28866 - Premia(VB) Tel. |
6|3403943305 Indirizzo E-mail: norma.braito@libero.it |
Orlando1973
04 Maggio 2015 alle ore 16:51
 0 -  0 - Inviato: 22 Ottobre 2020 alle ore 07:07
Il problema e nei pf iperdeterminati : righe e 4 -5 , se li togli non dà piu' errore .
Per iperdetermirali ( essendo presente PA) , come facevo io con ST (è un po' che non me ne capitano piu') , inserivo una 2° lettura praticamente uguale alla 1° e non mi ha mai dato errore .
Stessa cosa farei con GPS inserirei una 2° lettura praticamente uguale alla 1° , con poco scarto, ( a parte che non so' se serva con GPS) .
 0 -  0 - Inviato: 22 Ottobre 2020 alle ore 10:52
Giusto.
Da rivedere anche le impossibili coordinate del Punto Ausiliario 112 in riga 8.
