/ Forum / PREGEO e DOCFA / PREGEO 10.6.0 / Aiuto libretto Pregeo rilievo GPS
Autore Aiuto libretto Pregeo rilievo GPS
andreai3236
12 Aprile 2016 alle ore 15:29
 0 -  0 - Inviato: 13 Aprile 2016 alle ore 13:38
Buongiorno, ho redatto un TM con rilievo GPS ma il tecnico dell'AdE me lo ha sospeso perchè gli SQM sono fuori tolleranza in quanto la mia stazione è lontana dall'oggetto del rilievo.
In fase di redazione del tipo ho usato un punto come VRS, questo non dovrebbe ovviare al problema della stazione lontana?
Di seguito posto il libretto delle misure.
Grazie a chi mi vorrà dare una delucidazione in merito.
0|24032016|3|E713|0140|1358,1360|XX|GEOMETRA|VITERBO|
9|470|10|20|-28082|PREGEO 10.00-G,Stda 2.03|MC|-|
1|0000|4591400.50,964612.99,4306962.20|0.000|STRUMENTO: XX|
6|L2|23042015-09:31|01022016-15:33|RTK|PDOP=1|
2|100|3506.955,21207.251,-8391.254|0.00212600,0.00031900,0.00120800,0.00077500,0.00012300,0.00198900|PDOP=2|0.
000|Chiodo[VRS]|
2|101|3618.573,21057.348,-8470.529|0.00034500,0.00004600,0.00021800,0.00013300,0.00002000,0.00029300|PDOP=2|0.
000|
2|102|3617.395,21056.591,-8469.114|0.00037100,0.00005900,0.00022800,0.00013900,0.00002500,0.00029500|PDOP=2|0.
000|
2|103|3434.606,21476.912,-8388.346|0.00246400,0.00010500,0.00119200,0.00087000,0.00003000,0.00139600|PDOP=2|0.
000|
2|104|3435.134,21479.371,-8389.412|0.00203400,0.00011300,0.00096800,0.00074500,0.00004000,0.00114300|PDOP=2|0.
000|
2|105|3335.659,20935.988,-8127.906|0.00161200,0.00066300,0.00069600,0.00091900,0.00026300,0.00082900|PDOP=2|0.
000|
2|106|3335.183,20934.732,-8126.604|0.00331500,0.00265300,0.00103200,0.00327400,0.00056100,0.00092600|PDOP=2|0.
000|
2|107|3508.020,21207.330,-8391.812|0.00211300,0.00032500,0.00119400,0.00077800,0.00012400,0.00198100|PDOP=2|0.
000|Spigolo Fabbricato|
2|108|3506.888,21212.296,-8391.694|0.00210400,0.00033000,0.00118200,0.00078200,0.00012600,0.00197400|PDOP=2|0.
2|109|3504.343,21223.424,-8391.469|0.00209900,0.00033400,0.00117500,0.00078500,0.00012700,0.00197100|PDOP=2|0.
2|110|3513.979,21225.872,-8402.289|0.00209100,0.00033900,0.00116500,0.00078700,0.00012800,0.00196400|PDOP=2|0.
2|111|3515.917,21217.486,-8402.425|0.00197700,0.00039400,0.00096500,0.00076000,0.00022600,0.00160900|PDOP=2|0.
2|112|3513.746,21216.938,-8400.017|0.00197700,0.00039600,0.00096200,0.00076100,0.00022700,0.00160700|PDOP=2|0.
2|113|3515.690,21209.285,-8400.015|0.00197500,0.00039900,0.00095800,0.00076300,0.00022900,0.00160500|PDOP=2|0.
2|114|3514.374,21214.200,-8400.075|0.00197500,0.00040400,0.00095300,0.00076500,0.00023200,0.00160100|PDOP=2|0.
4|103|104|-50|*S*|
5|PF16/0140/E713|4.549|0|Spigolo S.W. fabbricato|
4|104|103|50|*S*|
5|PF16/0140/E713|4.208|0|Spigolo S.W. fabbricato|
4|103|0|
5|PF16/0140/E713|-0.3|Pedata primo gradino scala|
4|104|0|
5|PF16/0140/E713|-0.25|Pedata primo gradino scala|
4|105|106|0|*S*|
5|PF01/0090/E713|3.085|0.099|Colmo S. E. sito colonico Cerreto|
4|105|0|
5|PF01/0090/E713|4.832|Colmo tetto|
4|101|102|0|*S*|
5|PF01/0140/E713|5.064|0|Spigolo S. W. fabbricato|
4|101|0|
5|PF01/0140/E713|3.158|Piano terrazza primo piano|
6|Fabbricato|
7|9|107|108|109|110|111|112|114|113|RC|
7|0|107|NC|
8|PF01/0140/E713|79512.352000|-28309.526000|54|SPIG.IN ALTO AS.O.FABBR|
8|PF01/0140/E713|471.134000|03|PIANO DELLA TERRAZZA AL PRIMO PIANO|
8|PF01/0090/E713|79966.970000|-28367.610000|08|COLMO S.E.SITO COLONICO CERRETO|
8|PF01/0090/E713|482.160000|02|COLMO TETTO|
8|PF16/0140/E713|79630.426000|-27855.355000|56|SPIGOLO S.W.FABBRICATO|
8|PF16/0140/E713|459.547000|03|PEDATA PRIMO GRADINO SCALA DACCESSO AL PRIMO PIANO|
vic
13 Aprile 2005
 0 -  0 - Inviato: 13 Aprile 2016 alle ore 15:25
Le righe 4/5 del libretto non mi sembra rispettino la normativa (max prolungamento su allineamento, ecc.), togli le righe 4 dal libretto e fai girarlo su pregeo, se le sole righe gps non ti danno scarti il problema è negli allineamenti e squadri
lo schema che hai utilizzato per gli allineamenti è troppo forzato, oltre che non rispondente alla corretta procedura
andreai3236
 0 -  0 - Inviato: 13 Aprile 2016 alle ore 15:31
Grazie per le informazioni, ora provo quanto suggerito.
Ma il fatto che uso una stazione VRS non dovrebbe compensare la stazione lontana e i relativi SQM derivati?
 0 -  0 - Inviato: 13 Aprile 2016 alle ore 21:02
No. C'è VRS e VRS.
Ma è semplice accorgersene, basta leggersi i risultati dell'elaborazione.
