/ Forum / PREGEO e DOCFA / G.P.S. / Vendo GPS GNSS BASE ROVER
Autore Vendo GPS GNSS BASE ROVER
boluigi
01 Settembre 2003
 0 -  0 - Inviato: 01 Giugno 2013 alle ore 09:42
Vendo GPS GNSS BASE + ROVER gia' pronto per Galileo, Full optional, usato pochissimo vendo a meta' prezzo . Affare! Disponibile a qualsiasi prova anche confronto con altri gps! le caratteristiche:
www.spaziodolomiti.it/vendta-GPS.htm
Receiver
220 channels:
GPS: Synchronized L1 C/A, L2E, L2C, L5
GLONASS: Synchronized L1 C/A, L1 P, L2 C/A (restricted to GLONASS M) and L2 P
SBAS: Synchronized L1 C/A,L5
GIOVE-A: Optional synchronized L1 BOC, E5A, E5B and E5AltBOC
GIOVE-B: Optional synchronized L1 CBOC, E5A, E5B and E5AltBOC
GALILEO: upgrade
1. Tianbao Maxwell 6 advanced custom surveying GNSS technology
2. High precision multi-correlator used for GNSS pseudo-range
3. Extremely low-noise GNSS carrier phase measurements ensuring the accuracy in
the range of 0.001m at 1 Hz bandwidth
4. Mature Tianbao low-elevation tracking techniques
5. Initializing time less than 10s
6. Initializing reliability beyond 99.9%
7. Positioning output: 1 Hz, 2 Hz, 5 Hz, 10 Hz, 20Hz and 50 Hz positioning
output(10Hz default)
8. Original surveying and positioning output as high as 50 Hz
9. Differential supported: CMR, CMR+, RTCM 2.1, 2.2, 2.3, 3.0, 3.1
10. Output format:ASCII:NMEA-0183 GSV, AVR, RMC, HDT, VGK, VHD, ROT, GGK, GGA,
GSA, ZDA, VTG, GST PJT, PJK, BPQ, GLL, GRS, GBS and binary: Trimble GSOF
Built-in UHF Radio Communication
220MHz~240MHz and 450MHz~470MHz radio frequency bands for users from different countries to choose from
Wireless communication transfer rate at 19.2Kbps
Offering 16channels, and users can customize the built-in GPRS/CDMA network
communication part in the frequency table
Optional CDMA/3G network communication module
International standard automatic login
Hi-Target provide HD-CORS users with full-time free server, and users can build
their own servers as well.
Interface
Two RS-232 serial ports
One USB port
One Bluetooth wireless communications port
Two external DC power input port
One GSM/CDMA SIM card compartment
Two built-in lithium battery slot
One UHF antenna pedestal
Panel Key-Press and Indicator Lamps
2 panel key-presses, 1 power key-press, 1 function key-presses, with sound and
indicator lamps, key combinations can perform various settings on the receiver.
Receiver accuracy
Static accuracy: Horizontal: ±(2.5mm+1×10-6D) Vertical: ±(5mm+1×10-6D)
Rapid static accuracy: Horizontal: ±(5mm+1×10-6D)  Vertical: ±(10mm+1×10-6D)
RTK positioning accuracy: Horizontal: ±(10mm+1×10-6D)  Vertical: ±(20mm+1×10-6D)
Physical Specifications
Core control chip: ARM7,Built-in 64M Flash Drive
Weight: 1.1kg
Anti-2m natural drop, floatable, anti-1.2m soaking underwater
Built-in dual lithium battery, ensure switching power without interrupting your
surveying work
Double-battery capability 2800m Ah, voltage: 7.6V, continuous working up to 10
hours
External DC power supported, voltage range 7~36V, external/internal power
automatic switching
Main unit power: 2W
Environmental characteristics
Waterproof, dustproof, broken-resistant, IP67 grade
Operating temperature: -40℃~75℃, Storage temperature: -50℃~85℃
No condensation even at 100% humidity
grafos
05 Aprile 2011
venticano
 0 -  0 - Inviato: 01 Giugno 2013 alle ore 11:37
quale prezzo? mia e-mail porrugianc@libero.it
roczaga
18 Marzo 2013 alle ore 16:12
 0 -  0 - Inviato: 01 Giugno 2013 alle ore 12:44
E' possibile sapere gentilmente il prezzo?
La mia e-mail è: roczag@teletu.it
beretta
23 Marzo 2005
 0 -  0 - Inviato: 03 Giugno 2013 alle ore 18:02
CIAO VOLEVO SAPERE CORTESEMENTE IL PREZZO !
E SOPRATTUTTO DI DOVE SEI PER EVENTUALMENTE TESTARE INSIEME LO STRUMENTO
CIAO
mail: berenico@libero.it
Xpeppe
22 Febbraio 2007
 0 -  0 - Inviato: 27 Giugno 2013 alle ore 08:59
salve, il prezzo ?
mail spc_messaggi@hotmail.it
