il rilievo planimetrico non è connesso in corrispondenza della ripetizione n. 0 della stazione 20 |
fabio_78
08 Ottobre 2009
Salve ho un problema con un rilievo gps il libretto è il seguente: 0|16032013|19032013|A604|0140|62,180|MANFREDI VINCENZO|GEOMETRA|POTENZA| 9|450|10|20|-14910|10.00-G,APAG 1.13|13|Nota: | 6|DettaglioTipoAgg=(13) - TM - Inserim. nuovo fabbricato (con graffa o numero), sup. > 20 mq.Variazione numero| 1|0218|4664114.33,1321303.44,4132201.52|0.000| 6|L2|09012013-11:40|09012013-11:40|RTK|PDOP=1| 2|0001|4471.492,-23237.261,2437.935|0.000275475,0.000030726,0.000098159,0.000140139,0.000036465,0.000149211,0.843325734|PDOP=1|0.000| 2|1|4655.374,-23188.899,2124.828|0.000135722,0.000013207,0.000067286,0.000048703,0.000016622,0.000087162,0.779125690|PDOP=2|0.000| 2|2|4653.628,-23186.118,2126.264|0.000134988,0.000013643,0.000068358,0.000048188,0.000016885,0.000088356,1.130428672|PDOP=2|0.000| 2|3|4742.123,-23658.050,2148.852|0.000123034,0.000014975,0.000069548,0.000039084,0.000011788,0.000083392,1.083841443|PDOP=2|0.000| 2|4|4742.938,-23658.908,2147.922|0.000365578,-0.000046960,0.000207129,0.000054796,-0.000023391,0.000161320,1.061295867|PDOP=3|0.000| 2|5|4747.037,-23658.097,2141.528|0.000355882,-0.000042542,0.000202248,0.000052920,-0.000021181,0.000158577,0.974179327|PDOP=3|0.000| 2|6|4747.562,-23656.725,2140.479|0.000122584,0.000015510,0.000070195,0.000038398,0.000011631,0.000083736,0.891247511|PDOP=2|0.000| 2|7|4744.597,-23646.115,2139.672|0.000220986,0.000101160,0.000110920,0.000112225,0.000046681,0.000100491,1.219545722|PDOP=2|0.000| 2|8|4743.149,-23644.635,2140.737|0.000219432,0.000101199,0.000110366,0.000112594,0.000046305,0.000100166,0.982346237|PDOP=3|0.000| 2|9|4739.134,-23645.872,2147.209|0.000133414,0.000023711,0.000089436,0.000042602,0.000023749,0.000114483,1.473316908|PDOP=2|0.000| 2|10|4739.113,-23647.048,2148.005|0.000133415,0.000023953,0.000089752,0.000042547,0.000023900,0.000114930,1.353387594|PDOP=2|0.000| 2|11|4768.441,-23610.766,2089.601|0.000212291,0.000101289,0.000107317,0.000114293,0.000044179,0.000098268,0.914416850|PDOP=3|0.000| 2|12|4767.681,-23611.136,2091.532|0.000211616,0.000101309,0.000106993,0.000114471,0.000043952,0.000098062,1.299012899|PDOP=3|0.000| 2|13|4830.050,-23961.645,2184.917|0.000232905,0.000010934,0.000129820,0.000036079,0.000004518,0.000113564,0.938450634|PDOP=3|0.000| 2|14|4830.949,-23960.751,2183.621|0.000231685,0.000011512,0.000128983,0.000036004,0.000004758,0.000113054,1.087468863|PDOP=3|0.000| 2|15|4830.455,-23949.619,2180.868|0.000118045,0.000023669,0.000070599,0.000034951,0.000010541,0.000083294,1.324327111|PDOP=2|0.000| 2|16|4829.873,-23948.658,2181.235|0.000194908,0.000105196,0.000095619,0.000120820,0.000037102,0.000091487,1.002764463|PDOP=3|0.000| 2|17|4824.649,-23945.866,2186.532|0.000117581,0.000024462,0.000070135,0.000035063,0.000010566,0.000083239,0.871199429|PDOP=2|0.000| 2|18|4823.711,-23947.824,2188.074|0.000128988,0.000045632,0.000084933,0.000058858,0.000033455,0.000107688,1.650083661|PDOP=2|0.000| 2|19|4823.876,-23958.992,2191.248|0.000116598,0.000026089,0.000068999,0.000035444,0.000010647,0.000083170,1.814119220|PDOP=2|0.000| 2|20|4824.899,-23960.591,2190.534|0.000122806,0.000022426,0.000086091,0.000037866,0.000000119,0.000130192,1.277338266|PDOP=2|0.000| 2|PF33|4827.326,-23842.302,2117.943|0.000078400,0.000013586,0.000034849,0.000035117,-0.000012886,0.000114351,1.450821757|PDOP=2|0.000| 2|PF22|4655.321,-23732.649,2308.299|0.000081069,0.000012568,0.000031869,0.000034466,-0.000009720,0.000112099,1.093253613|PDOP=1|0.000| 4|1|2|-50| 5|0002|3.750|0.000| 4|2|0002|0| 5|0002|2.950|0.000| 4|3|4|-50| 5|0003|1.110|0.000| 4|4|0003|0| 5|0003|0.980|0.000| 4|5|6|-50| 5|0004|1.150|0.000| 4|6|0004|0| 5|0004|1.240|0.000| 4|7|8|-50| 5|0005|1.470|0.000| 4|8|0005|0| 5|0005|1.500|0.000| 4|9|10|-50| 5|0006|1.160|0.000| 4|10|0006|0| 5|0006|0.780|0.000| 4|11|12|-50| 5|0007|1.860|0.000| 4|12|0007|0| 5|0007|0.880|0.000| 4|13|14|-50| 5|0008|1.130|0.000| 4|14|0008|0| 5|0008|1.440|0.000| 4|15|16|-50| 5|0009|1.130|0.000| 4|16|0009|0| 5|0009|0.840|0.000| 4|17|18|-50| 5|0010|2.280|0.000| 4|18|0010|0| 5|0010|1.290|0.000| 4|19|20|-50| 5|0011|1.440|0.000| 4|20|0011|0| 5|0011|1.390|0.000| 4|1|0.00| 5|0002|0.00| 4|3|0.00| 5|0003|0.00| 4|5|0.00| 5|0004|0.00| 4|7|0.00| 5|0005|0.00| 4|9|0.00| 5|0006|-0.10| 4|11|0.00| 5|0007|-0.65| 4|13|0.00| 5|0008|0.00| 4|15|0.00| 5|0009|0.00| 4|17|0.00| 5|0010|0.00| 4|19|0.00| 5|0011|0.00| l'errore che mi da è il seguente:. il rilievo planimetrico non è connesso in corrispondenza della ripetizione n. 0 della stazione 20 tra l'altro se al posto dei pf inserisco dei punti casuali l'errore non me lo da: mi sapete aiutare?
Hai associato il file delle misurate che fornisce l'Agenzia? Buon lavoro
fabio_78
08 Ottobre 2009
si il file PZ130204.dis è associato ho appena scaricato il file aggiornato dal sito dell'agenzia ma non risolvo il problema
geosys
06 Novembre 2005
Roverbella (MN)
Ciao, io di solito in riga 1 quando imposto la prima (e unica) stazione - base la indico con il numero 1000 (rilievo Gps) o 100 (rilievo celerimetrico); ho notato che la tua stazione in riga 1 invece ha valore 0218; forse può essere questo il problema? Saluti, Valeria
"it9gvo" ha scritto: Hai associato il file delle misurate che fornisce l'Agenzia? "geosys" ha scritto: Ciao, io di solito in riga 1 quando imposto la prima (e unica) stazione - base la indico con il numero 1000 (rilievo Gps) o 100 (rilievo celerimetrico); ho notato che la tua stazione in riga 1 invece ha valore 0218; forse può essere questo il problema? Il problema non dipende ne dalle misurate e ne dalla Stazione permanente, ma dalla confusione presente nel libretto.
Non c'entrerà niente, ma mi sembra che il PF 22 e 33 non esistano sul foglio 14 di Balvano. E poi una considerazione sui nomi dei punti: a me va insieme il cervello a vedere che convivono due punti distinti che si chiamano 1 e 0001.
Salve Urge: Un bel corso su pregeo; Lettura approfondita della circolare 2/88; Lettura approfondita della relativa Istruzione sul rilevamento; Ai miei tempi si diceva: ma chi ti ha dato la patente? A parte gli scherzi, con quella numerazione non vai da nessuna parte. Con affetto cordialmente
geosys
06 Novembre 2005
Roverbella (MN)
infatti.... era sottinteso che impostando le varie stazioni con numerazione 100, 200 o 1000 le righe 2 dei punti osservati dovrebbero seguire in automatico la numerazione dipendente dal numero della stazione origine...
giulio.sciutto
Giulio
02 Settembre 2015 alle ore 18:05
Novi Ligure
0|29072019|77672|F965|015A|255|SCIUTTO GIULIO|ARCHITETTO|ALESSANDRIA| 9|150|10|20|14311|PREGEO 10.00-G,APAG 2.08|TM|STONEX S8| 6|MONTESSORO VALERIA| 6|Libretto GPS| 1|0045|4482227.43,693174.79,4469694.99|0.000|Base GPS [WGS84-ETRF2000]| 6|L2|24072019-10:15|24072019-11:06|RTK|PDOP=3| 2|1000|0.359,8.140,-9.871|0.0005227850,0.0000096350,0.0003865940,0.0000467570,0.0000136580,0.0003709190|PDOP=4|0.000|Picchetto[VRS]| 2|1|-0.652,6.629,-8.307|0.0005578850,0.0000259370,0.0004315330,0.0000466470,0.0000274400,0.0004147590|PDOP=4|0.000|Picchetto| 2|2|-2.041,8.470,-7.221|0.0005749020,0.0000329930,0.0004497030,0.0000473540,0.0000335190,0.0004325640|PDOP=4|0.000|Picchetto| 2|3|1.188,-1.142,-8.401|0.0004600210,0.0000306700,0.0003358200,0.0000480310,0.0000298600,0.0003186760|PDOP=2|0.000|Picchetto| 2|4|0.272,-0.376,-7.761|0.0004811310,0.0000452920,0.0003665870,0.0000484690,0.0000407670,0.0003521490|PDOP=2|0.000|Picchetto| 2|PF07/015A/F965|-92.052,-9.196,83.014|0.0002675620,0.0000549280,0.0002263560,0.0000566480,0.0000534550,0.0002821220|PDOP=2|0.000|Picchetto| 2|PF04/015A/F965|50.850,-81.670,-47.157|0.0001534290,-0.0000160130,0.0000797710,0.0000669370,0.0000354250,0.0001546100|PDOP=2|0.000|Picchetto| 2|PF05/015A/F965|86.415,214.501,-126.334|0.0001562060,0.0000133990,0.0000994460,0.0000550490,-0.0000322620,0.0006197060|PDOP=2|0.000|Picchetto| 2|5|-129.661,202.299,88.774|0.0002032730,0.0000621310,0.0001372310,0.0000781520,0.0000595800,0.0001660110|PDOP=2|0.000|Picchetto| 2|6|-130.772,201.254,90.159|0.0001462750,0.0000403290,0.0000982170,0.0000563230,0.0000312690,0.0001233540|PDOP=2|0.000|Picchetto| 2|1002|-12.168,7.485,5.859|0,0,0,0,0,0|PDOP=3|2.000|sf| 2|1003|-10.812,-3.055,6.532|0,0,0,0,0,0|PDOP=3|2.000|Spigolo fabbricato| 2|1009|-4.867,-0.532,0.154|0,0,0,0,0,0|PDOP=3|2.000|sf| 2|1010|-4.590,-0.515,-0.131|0,0,0,0,0,0|PDOP=3|2.000|Spigolo fabbricato| 6|Libretto allineamenti e squadri| 4|1|2|-44.2791|Intersezione 1| 5|1001|9.010|0.000|Picchetto| 4|2|1001|0.0000|Intersezione 2| 5|1001|7.240|0.000|Picchetto| 4|3|4|-49.9718|Intersezione 1| 5|1004|10.376|0.000|Picchetto| 4|4|1004|0.0000|Intersezione 2| 5|1004|9.469|0.000|Picchetto| 4|5|6|-55.1598|Intersezione 1| 5|PF06/015A/F965|6.070|0.000|Picchetto| 4|6|PF06/015A/F965|0.0000|Intersezione 2| 6|Libretto livellazioni| 4|1|1001|0.000|0.009|Picchetto| 4|3|1004|0.000|0.109|Picchetto| 4|5|PF06/015A/F965|0.000|-0.083|Picchetto| 6|casa| 7|7|1001|1002|1003|1004|1009|1010|1001|RC| 6|PUNTO VERTICE| 7|1|1002|PV| 6|PUNTO VERTICE| 7|1|1003|PV| 8|PF06/015A/F965|-15521.000000|14435.800000|12|ASSE PALO SOSTEGNO CANCELLO| 8|PF06/015A/F965|999.000|3|ASSE PALO SOSTEGNO CANCELLO;altimetrico = SOMMITA DEL PALETTO| 8|PF05/015A/F965|-15828.700000|14429.460000|54|SPIGOLO RECINZIONE N-W DEL FABBRICATO| 8|PF05/015A/F965|999.000|3|SPIGOLO RECINZIONE N-W DEL FABBRICATO;altimetrico = SOMMITA MURETTO| 8|PF04/015A/F965|-15715.643000|14142.331000|54|SPIGOLO S-W DEL FABBRICATO| 8|PF04/015A/F965|999.000|3|SPIGOLO S-W DEL FABBRICATO;altimetrico = ESTRADOSSO TERRAZZO| 8|PF07/015A/F965|-15531.273000|14235.370000|54|SPIGOLO PILASTRO C.A. CANCELLO| 8|PF07/015A/F965|999.000|3|SPIGOLO PILASTRO C.A. CANCELLO;altimetrico = A TERRA| BUONA SERA ANCHE AME SUCCEDE LO STESSO ERRORE " PF07/015A/F965 Trovato nella TAF PF04/015A/F965 Trovato nella TAF PF05/015A/F965 Trovato nella TAF PF06/015A/F965 Trovato nella TAF l'Est media definita nel record 9 e' differente piu' di 5000 m dalla media delle Est dei PF appartenenti allo stesso riferimento dell'oggetto del rilievo: il calcolo prosegue nella rappresentazione cartografica Cassini-Soldner: Il rilievo planimetrico NON E' CONNESSO in corrispondenza della ripetizione n. 0 della stazione 6 " NON TROVO SPIEGAZIONE, CHIEDO CORTESEMENTE UNA DRITTA SULLA RISOLUZIONE DEL PROBLEMA. GRAZIE "
Orlando1973
04 Maggio 2015 alle ore 16:51
Buongiorno , per l'est media non c'e' problema . Per il resto basta guardare gli interventi precedenti e c'e' la soluzione , ovvero rinomina i punti 1-2-3-4-5-6 ,con 1001-1004 .......... Perche' una numerazione cosi a casaccio ?
ciabattoni
26 Giugno 2007
"fabio_78" ha scritto: Salve ho un problema con un rilievo gps il libretto è il seguente: 0|16032013|19032013|A604|0140|62,180|MANFREDI VINCENZO|GEOMETRA|POTENZA| 9|450|10|20|-14910|10.00-G,APAG 1.13|13|Nota: | 6|DettaglioTipoAgg=(13) - TM - Inserim. nuovo fabbricato (con graffa o numero), sup. > 20 mq.Variazione numero| 1|0218|4664114.33,1321303.44,4132201.52|0.000| 6|L2|09012013-11:40|09012013-11:40|RTK|PDOP=1| 2|0001|4471.492,-23237.261,2437.935|0.000275475,0.000030726,0.000098159,0.000140139,0.000036465,0.000149211,0.843325734|PDOP=1|0.000| 2|1|4655.374,-23188.899,2124.828|0.000135722,0.000013207,0.000067286,0.000048703,0.000016622,0.000087162,0.779125690|PDOP=2|0.000| 2|2|4653.628,-23186.118,2126.264|0.000134988,0.000013643,0.000068358,0.000048188,0.000016885,0.000088356,1.130428672|PDOP=2|0.000| 2|3|4742.123,-23658.050,2148.852|0.000123034,0.000014975,0.000069548,0.000039084,0.000011788,0.000083392,1.083841443|PDOP=2|0.000| 2|4|4742.938,-23658.908,2147.922|0.000365578,-0.000046960,0.000207129,0.000054796,-0.000023391,0.000161320,1.061295867|PDOP=3|0.000| 2|5|4747.037,-23658.097,2141.528|0.000355882,-0.000042542,0.000202248,0.000052920,-0.000021181,0.000158577,0.974179327|PDOP=3|0.000| 2|6|4747.562,-23656.725,2140.479|0.000122584,0.000015510,0.000070195,0.000038398,0.000011631,0.000083736,0.891247511|PDOP=2|0.000| 2|7|4744.597,-23646.115,2139.672|0.000220986,0.000101160,0.000110920,0.000112225,0.000046681,0.000100491,1.219545722|PDOP=2|0.000| 2|8|4743.149,-23644.635,2140.737|0.000219432,0.000101199,0.000110366,0.000112594,0.000046305,0.000100166,0.982346237|PDOP=3|0.000| 2|9|4739.134,-23645.872,2147.209|0.000133414,0.000023711,0.000089436,0.000042602,0.000023749,0.000114483,1.473316908|PDOP=2|0.000| 2|10|4739.113,-23647.048,2148.005|0.000133415,0.000023953,0.000089752,0.000042547,0.000023900,0.000114930,1.353387594|PDOP=2|0.000| 2|11|4768.441,-23610.766,2089.601|0.000212291,0.000101289,0.000107317,0.000114293,0.000044179,0.000098268,0.914416850|PDOP=3|0.000| 2|12|4767.681,-23611.136,2091.532|0.000211616,0.000101309,0.000106993,0.000114471,0.000043952,0.000098062,1.299012899|PDOP=3|0.000| 2|13|4830.050,-23961.645,2184.917|0.000232905,0.000010934,0.000129820,0.000036079,0.000004518,0.000113564,0.938450634|PDOP=3|0.000| 2|14|4830.949,-23960.751,2183.621|0.000231685,0.000011512,0.000128983,0.000036004,0.000004758,0.000113054,1.087468863|PDOP=3|0.000| 2|15|4830.455,-23949.619,2180.868|0.000118045,0.000023669,0.000070599,0.000034951,0.000010541,0.000083294,1.324327111|PDOP=2|0.000| 2|16|4829.873,-23948.658,2181.235|0.000194908,0.000105196,0.000095619,0.000120820,0.000037102,0.000091487,1.002764463|PDOP=3|0.000| 2|17|4824.649,-23945.866,2186.532|0.000117581,0.000024462,0.000070135,0.000035063,0.000010566,0.000083239,0.871199429|PDOP=2|0.000| 2|18|4823.711,-23947.824,2188.074|0.000128988,0.000045632,0.000084933,0.000058858,0.000033455,0.000107688,1.650083661|PDOP=2|0.000| 2|19|4823.876,-23958.992,2191.248|0.000116598,0.000026089,0.000068999,0.000035444,0.000010647,0.000083170,1.814119220|PDOP=2|0.000| 2|20|4824.899,-23960.591,2190.534|0.000122806,0.000022426,0.000086091,0.000037866,0.000000119,0.000130192,1.277338266|PDOP=2|0.000| 2|PF33|4827.326,-23842.302,2117.943|0.000078400,0.000013586,0.000034849,0.000035117,-0.000012886,0.000114351,1.450821757|PDOP=2|0.000| 2|PF22|4655.321,-23732.649,2308.299|0.000081069,0.000012568,0.000031869,0.000034466,-0.000009720,0.000112099,1.093253613|PDOP=1|0.000| 4|1|2|-50| 5|0002|3.750|0.000| 4|2|0002|0| 5|0002|2.950|0.000| 4|3|4|-50| 5|0003|1.110|0.000| 4|4|0003|0| 5|0003|0.980|0.000| 4|5|6|-50| 5|0004|1.150|0.000| 4|6|0004|0| 5|0004|1.240|0.000| 4|7|8|-50| 5|0005|1.470|0.000| 4|8|0005|0| 5|0005|1.500|0.000| 4|9|10|-50| 5|0006|1.160|0.000| 4|10|0006|0| 5|0006|0.780|0.000| 4|11|12|-50| 5|0007|1.860|0.000| 4|12|0007|0| 5|0007|0.880|0.000| 4|13|14|-50| 5|0008|1.130|0.000| 4|14|0008|0| 5|0008|1.440|0.000| 4|15|16|-50| 5|0009|1.130|0.000| 4|16|0009|0| 5|0009|0.840|0.000| 4|17|18|-50| 5|0010|2.280|0.000| 4|18|0010|0| 5|0010|1.290|0.000| 4|19|20|-50| 5|0011|1.440|0.000| 4|20|0011|0| 5|0011|1.390|0.000| 4|1|0.00| 5|0002|0.00| 4|3|0.00| 5|0003|0.00| 4|5|0.00| 5|0004|0.00| 4|7|0.00| 5|0005|0.00| 4|9|0.00| 5|0006|-0.10| 4|11|0.00| 5|0007|-0.65| 4|13|0.00| 5|0008|0.00| 4|15|0.00| 5|0009|0.00| 4|17|0.00| 5|0010|0.00| 4|19|0.00| 5|0011|0.00| l'errore che mi da è il seguente:. il rilievo planimetrico non è connesso in corrispondenza della ripetizione n. 0 della stazione 20 tra l'altro se al posto dei pf inserisco dei punti casuali l'errore non me lo da: mi sapete aiutare? ANCHIO HO QUESTO PROBBLEMA CON QUESTO LIBRETTO SAPETE AIUTARMI? 0|07052024|10524|L103|056A|1114|RASTELLI MAURO|INGEGNERE|TERAMO| 9|300|10|20|-42617|PREGEO 10.00-G,APAG 2.12|TM|GPS E-Survey E300 Pro| 1|100|4562190.370,1115409.630,4301409.370|0.000|Chiodo quota a terra (WGS84-ETRF2000)| 6|L2|08042024-07:58|08042024-07:58|RTK|PDOP=3| 2|101|3.367,4.917,-3.614|0.0012096061,-0.0000154985,0.0007187386,0.0005946284,0.0001181132,0.0008517274|PDOP=1|0.000|Spigolo fabbricato - quota a terra| 2|102|6.115,8.297,-8.429|0.0012441268,0.0003168866,0.0005883739,0.0002540629,0.0001809204,0.0005454089|PDOP=1|0.000|spigolo fabbricato| 2|103|0.447,19.058,-5.241|0.0005129327,0.0002422124,0.0002479508,0.0002490465,0.0000766017,0.0003284805|PDOP=2|0.000|spigolo fabbricato| 2|104|-3.287,15.672,-0.420|0.0000549125,0.0000231097,0.0000405183,0.0000304157,0.0000163893,0.0000725853|PDOP=1|0.000|spigolo fabbricato| 2|PF35/056A/L103|-38.549,5.033,41.903|0.0001684254,0.0000692051,0.0000865293,0.0000801023,0.0000425882,0.0001212227|PDOP=1|0.000|spigolo recinzione| 2|PF35/056A/L103|-38.549,5.033,41.898|0.0001977337,0.0000821164,0.0001014910,0.0000962417,0.0000505482,0.0001436423|PDOP=2|0.000|spigolo recinzione| 2|PF35/056A/L103|-38.563,5.021,41.922|0.0001929407,0.0000799689,0.0000990995,0.0000935084,0.0000492397,0.0001399344|PDOP=2|0.000|spigolo recinzione| 2|PF31/056A/L103|116.337,-49.119,-103.703|0.0002773787,0.0002024922,0.0000591802,0.0002395040,0.0000236372,0.0001444521|PDOP=2|0.000|spigolo fabbricato| 2|PF31/056A/L103|116.323,-49.117,-103.682|0.0003434879,0.0002509990,0.0000723970,0.0002953932,0.0000290603,0.0001779486|PDOP=1|0.000|spigolo fabbricato| 2|PF31/056A/L103|116.318,-49.105,103.729|0.0003534102,0.0002587178,0.0000739815,0.0003038756,0.0000298440,0.0001803602|PDOP=2|0.000|spigolo fabbricato| 2|PF02/0570/L103|-122.224,2813166,36.275|0.0000259763,0.0000049754,0.0000188737,0.0000089072,0.0000014546,0.0000288662|PDOP=2|0.000|spigolo fabbricato| 2|PF02/0570/L103|-122.222,281.162,36.267|0.0000264368,0.0000050072,0.0000192075,0.0000090193,0.0000015113,0.0000291781|PDOP=2|0.000|spigolo fabbricato| 2|PF02/0570/L103|-122.232,281.154,36.276|0.0000257582,0.0000048831,0.0000186995,0.0000087799,0.0000014980,0.0000283692|PDOP=3|0.000|spigolo fabbricato| 7|5|101|102|103|104|101|RC|AAA+|1114| 8|PF02/0570/L103|114166.626000|-42394.271000|54|SPIGOLO OVEST FABBRICATO| 8|PF02/0570/L103|9999.000000|04|QUOTA SU MURETTO DI SOSTEGNO| 8|PF31/056A/L103|113965.030000|-42774.823000|56|SPIGOLO SUD EST FABBRICATO| 8|PF31/056A/L103|250.000000|04|QUOTA A TERRA| 8|PF35/056A/L103|114164.555000|-42680.503000|12|ANGOLO MURO DI REC.| 8|PF35/056A/L103|9999.000000|04|PUNTO A TERRA|
Ultime news
